alternator voltage output
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Lightning-List
curts63
PostPosted: Sat Mar 07, 2015 1:21 pm    Post subject: alternator voltage output Reply with quote
My question is this, what is the normal output of the alternator in voltage? My volt meter is reading up to 14.7 volts when running around 3000rpm. Is this normal or should it max out around 13.7?
If this is high, I guess I need a new regulator? My problem is the Garmin system seems to fluctuate as the voltage gets up to 14.5 or more volts. When you pull back the throttle and let the voltage drop, things settle down.
Curt
- The Matronics Lightning-List Email Forum -
http://www.matronics.com/Navigator?Lightning-List
UK Clive
PostPosted: Sat Mar 07, 2015 2:18 pm    Post subject: alternator voltage output Reply with quote
Both mine top out at 14.4 v
Curt
http://forums.matronics.com/viewtopic.php?p=439130#439130
Wayne Lenox
PostPosted: Sat Mar 07, 2015 2:49 pm    Post subject: alternator voltage output Reply with quote
Curt
My Lightning voltage when up to speed is 14.3 volts most of the time. Some times it is 14.2volts. If you are looking for 13.7 volts, that is way to low. If your battery is charged up before departure, your alternator should stay near 14.2 volts.
Wayne
2008 Lightning kit 63 3300 Jabiru.
N123wl
curts63
PostPosted: Sun Mar 08, 2015 3:25 am    Post subject: Re: alternator voltage output Reply with quote
most of the time when I take off, the voltage is around 12.5 and shortly after, the voltage will climb to the 14.7 range. it's at that point, the tachometer starts acting erratically.
curts63
PostPosted: Wed Jul 29, 2015 10:46 am    Post subject: Re: alternator voltage output Reply with quote
for whatever it's worth. During my installation of the Garmin G3X panel, the tachometer would not give a steady reading, that's why I started this discussion. What I found out was, the current wave put out by the alternator needed to have a filter installed to "quiet" it down to get a reliable signal. My avionics guy made one from a discussion that I had with Bob Nuckells from another forum here.
wb2ssj(at)rochester.rr.co
PostPosted: Wed Jul 29, 2015 4:50 pm    Post subject: alternator voltage output Reply with quote
Could you post the details of the discussion.
Tex
curts63
PostPosted: Sun Aug 02, 2015 4:06 pm    Post subject: Re: alternator voltage output Reply with quote
here is the link/web address for the discussion. Curt
http://forums.matronics.com/viewtopic.php?t=16757545
PostPosted: Mon Aug 03, 2015 5:19 pm    Post subject: alternator voltage output Reply with quote
Curt, thanks for the info, much appreciated.
Tex
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Lightning-List All times are GMT - 8 Hours
You cannot download files in this forum
