JabiruEngine-List: Unusual Oil Leak
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Lightning-List
mdare(at)dentaled.ca
PostPosted: Wed Sep 23, 2015 11:55 am    Post subject: JabiruEngine-List: Unusual Oil Leak Reply with quote
I have had the same issue but had not done anything for it. Sounds like a great idea.
On Wed, 23 Sep 2015 at 12:43 Linda Mathias <lbmathias1(at)gmail.com (lbmathias1(at)gmail.com)> wrote:
[quote]Dear Jabiru engine owners,
        I have been experiencing a strange phenomenon: oil on the top of my dipstick.   After thoroughly checking the engine for leaks and finding none, I discovered the cause is capillary action up the dipstick through the plastic cap.   I fixed it by pushing Liquid Nail around the aluminum tube opening in the plastic cap and letting it dry thoroughly before flying; cleaning off any excess keeps it still looking good.  If you look at the bottom of the cap, you can see just enough space around the aluminum for a bit of oil to go through.  I think any heat resistant sealant would work; the Liquid Nail held through a 2.5 hour flight but if needed, I will add some more and keep a close eye on it.
Blue skies,
Linda Mathias
Lightning with Jabiru 3300
ist" target="_blank">http://www.matronics.com/Navigator?JabiruEngine-List
tp://forums.matronics.com
- The Matronics Lightning-List Email Forum -
http://www.matronics.com/Navigator?Lightning-List
matronics(at)rtist.nl
PostPosted: Wed Sep 23, 2015 12:01 pm    Post subject: JabiruEngine-List: Unusual Oil Leak Reply with quote
I had the same for years. Fixed it using Loctite 243, same result. This is pretty common I hear.
Happy landings!
Rob
On 9/23/2015 9:43 PM, Linda Mathias wrote:
[quote] Dear Jabiru engine owners,
Blue skies,
Linda Mathias
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Lightning-List All times are GMT - 8 Hours
You cannot download files in this forum
