Answered my own question re Van's Aircraft tachometer
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> CorvairEngines-List
echristley(at)att.net
PostPosted: Fri Oct 02, 2015 6:06 pm    Post subject: Answered my own question re Van's Aircraft tachometer Reply with quote
As best I can tell, the tachometer used by Van's Aircraft and also sold by Aircraft Spruce is a Isspro model, and uses a sender that produces 8 pulses per revolution. Fairly certain that our coils will be producing 3 pulses per revolution. This is rather disheartening, because now I have to find a tach that will fit a standard 2.25" instrument hole and bolt pattern.
- The Matronics CorvairEngines-List Email Forum -
http://www.matronics.com/Navigator?CorvairEngines-List
tigerized(at)gmail.com
PostPosted: Fri Oct 02, 2015 7:53 pm    Post subject: Answered my own question re Van's Aircraft tachometer Reply with quote
Ernest, I first used an E1 from MGL avionics. It worked well with a few wraps about the high tension lead to provide the tach input.
I have this unit sitting on a shelf collecting dust if you're interested, as I've replaced it with another engine monitor package.
Want it? Make a ridiculous offer.
Rick Lindstrom
On Fri, Oct 2, 2015 at 7:05 PM, Ernest Christley <echristley(at)att.net (echristley(at)att.net)> wrote:
[quote]As best I can tell, the tachometer used by Van's Aircraft and also sold by Aircraft Spruce is a Isspro model, and uses a sender that produces 8 pulses per revolution.  Fairly certain that our coils will be producing 3 pulses per revolution.  This is rather disheartening, because now I have to find a tach that will fit a standard 2.25" instrument hole and bolt pattern.
/a>
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> CorvairEngines-List All times are GMT - 8 Hours
