change in rudder trim
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Glasair-List
mppalmer(at)aol.com
PostPosted: Fri Oct 23, 2015 12:08 pm    Post subject: change in rudder trim Reply with quote
cable spring tension changed, rudder cable slipped,
wear in the rudder hinge pin, the wheels or wheel pantsĀ
aren't aligned, engine mounts, hatch seal burbling out air,
nose wheel slightly cocked, cowling pins worn, aflap position has changed
Thanks. The first thing I thought about was a broken engine mount. But nothing that I can see. (I had a friend tug on the prop from different angles to see if anything popped open.)
As for the other catastrophic changes, since I didn't touch most of those, I don't see how they changed.
But I have observed that an inner cowl hinge (one near the nose) has partially broken thru. Been meaning to replace it. It's possible that that part of the cowl could be opening up in flight, causing a yaw. (I would expect that I would see that, or see some evidence of chaffing if it were lifting open.)
I'll report back if that fixes the rudder trim problem after I replace the hinge. I don't like it when things suddenly change without an obvious cause.
Mike <><
- The Matronics Glasair-List Email Forum -
http://www.matronics.com/Navigator?Glasair-List
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Glasair-List All times are GMT - 8 Hours
