Bill Vincent
Posted: Fri Jun 30, 2006 3:27 pm Post subject: Vortex Generators |
Hi Gang
Just received my July 2006, EAA Sport Pilot magazine.On page 27, there is a story about vortex generators, cuffs, fences and stall strips. Since there has been numerous discussions on this subject I thought some of you may be interested in the article.
Bill Vincent
Firestar II
Upper Peninsula of Michigan
_________________ Bill Vincent
Firestar II
Upper Peninsula of Michigan |
David Lucas
Joined: 10 Jan 2006 Posts: 79 Location: Europe. based Amsterdam NL
Posted: Wed Jul 05, 2006 8:21 am Post subject: Re: Vortex Generators |
G'day all !
There was also an article about VG's in 'Aviation Consumer' Feb 2006 which was generaly positive over their use. The article refered to their use mainly on Cessna 172 through to the Beech Duke type of aircraft. One 'letter to the editor' in the April 2006 issue brought up an interesting point re wing loading in turbulence.
The VG's enable the wing to fly at a higher angle of attack and thus lower the stall speed, Vs, but in turbulence you want the wing to stall before the design limit load of the structure is reached. Va (maneuvering speed) gives you protection here.
With VG's the aircrafts Va is lowered proportionally to the decrease in Vs therefore the writer recomended to calculate and record the lowered Va for a VG equipt aircraft.
Sounds logical for the aircraft types mentioned. Guess it applies to Kolbs too.
David.
(The older I get, the smarter I was !)
Posted: Wed Jul 05, 2006 9:11 am Post subject: Vortex Generators |
Beech Duke type of aircraft. |
| David.
Don't think there is much relationship between the aircraft tested and
a Kolb.
We fly very slow, normally.
If by chance we encounter severe turbulence, there is not problem
slowing down to prevent overstressing the Kolb. First of all, your
body will not be able to tolerate nearly the abuse from turbulence
that your Kolb will. Based on some experience, when I have to hang on
to the bottom of the seat to keep from getting beat up, it is an
unconditioned response to reduce power and airspeed.
Soon as I can figure out how VG's can improve performance of my mkIII,
I run right out and buy a set.
_________________ John Hauck
Titus, Alabama |
Possum
Posted: Wed Jul 05, 2006 9:33 pm Post subject: Vortex Generators |
At 01:06 PM 7/5/2006, you wrote:
>--> Kolb-List message posted by: "John Hauck" <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)>
>john h
I don't have the luxury of flaps, but I think even "you" would be
impressed - you might even be able to "hover" - like the ole days
in the chopper.
$100.00 and a little of the right kind of double sided tape,
who knows??
Posted: Thu Jul 06, 2006 5:13 am Post subject: Vortex Generators |
| who knows??
Possum:
Loan me a hundred, "pay day stakes".
hauck
Titus, Alabama |
Posted: Thu Jul 06, 2006 6:00 am Post subject: Vortex Generators |
When John's 912 heads west and he puts a two cylinder John Deere
engine on the Kolb, that's when he will really need some vortex
generators.
That would sound better than a Harley twin poppin overhead.
-BB do not archive
On 6, Jul 2006, at 9:11 AM, John Hauck wrote:
| who knows??
Possum:
hauck
Posted: Thu Jul 06, 2006 6:14 am Post subject: Vortex Generators |
| generators.
| -BB
Bob B/Gang:
Guess I could go with the 1937 JD B. It has a 149 cu in two cyl.
Runs good too. A little heavy though. Probably need VGs top and
bottom of everything.
BTW: It would sound good. Running a straight SS stack on it now.
Have to wear ear plugs when I work it hard.
DO NOT ARCHIVE
Titus, Alabama |
Posted: Fri Jul 07, 2006 12:03 pm Post subject: Vortex Generators |
At 06:26 PM 6/30/06 -0500, you wrote:
| Quote: | Hi Gang Just received my July 2006,
strips.
Bill,
I just received my copy today. It was a good article, and it pretty much
indicates what effect VG's can have on a Kolb. One of the planes shown was
a "vintage J-3 Cub".
I have seen VG's on thick wing heavy lifter STOL aircraft. Just before I
moved to Indiana, a fellow moved a MOOSE, Murphy Aircraft Mfg. Ltd., into
the communal hangar. It had vortex generators on top of the wings, on the
bottom of the horizontal stabilizers, and on each side of the vertical
stabilizer. I took my step stool down and measured things. The VG placement
on the Moose wing was almost identical in proportion to what I have on the
FireFly. The wing chord was a little longer than my FireFly but the span
was 14 feet larger. It was a good feeling to hangar with such a strong
beast.
Before I closed the hangar door for the last time and slipped the key under
the door, I looked at it again. It was a rare occurance, that a MOOSE
showed up at Perryville, Missouri, and I doubt that one will find its way to
Winchester, Indiana.
Jack B. Hart FF004
Winchester, IN
