LycomingEngines-List Digest: 3 Msgs - 12/18/15
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> LycomingEngines-List
goldpilot(at)AOL.COM
PostPosted: Sat Dec 19, 2015 9:26 am    Post subject: LycomingEngines-List Digest: 3 Msgs - 12/18/15 Reply with quote
Hi Matt. My O-360 in my Tiger turns around 2300 on the takeoff run. If I check fuel flow at liftoff and immediately after I show about 17.5 gph on my JPI. During climb out since I am at or below 75% power I will lean it back down to about 14 gallons per hour. EGT and CHT numbers look really nice and low.
David---------- Forwarded message ----------
DavidOn Dec 19, 2015 12:01 AM, LycomingEngines-List Digest Server <lycomingengines-list(at)matronics.com> wrote:
Today's complete LycomingEngines-List Digest can also be found in either of the
two Web Links listed below.  The .html file includes the Digest formatted
and Message Navigation.  The .txt file includes the plain ASCII version
of the LycomingEngines-List Digest and can be viewed with a generic text editor
HTML Version:
    http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 15-12-18&Archive=LycomingEngines
Text Version:
    http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 15-12-18&Archive=LycomingEngines
                           LycomingEngines-List Digest Archive
                     Total Messages Posted Fri 12/18/15: 3
Today's Message Index:
     1. 02:40 PM - Lycoming O-360 Fuel Flow Rate  (Matt Dralle)
     2. 03:43 PM - Re: Lycoming O-360 Fuel Flow Rate  (Ed Gilroy)
     3. 06:24 PM - Re: Lycoming O-360 Fuel Flow Rate  (Deems Herring)
________________________________  Message 1  _____________________________________
Time: 02:40:43 PM PST US
Subject: Lycoming O-360 Fuel Flow Rate
I'm still chasing down this weird problem with low fuel flow rates on the RV-6.
I've replaced the mechanical fuel pump and got a rebuilt 4-5 carburetor, both
of which were well over do for replacement/overhaul anyway.  I haven't put the
cowling back on yet, but I did a static run up to about 2350-2400 and am seeing
about 9gph, which seems low to me?
I pulled the fuel line off the carburetor and turned the electric fuel pump on
and saw about 21 GPH flow.  Is that considered "normal" or too low?
Thanks for the feedback,
Matt
RV-8 #82880 N998RV "Ruby Vixen"
http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log
http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log
Status: 210+ Hours TTSN - Version 2.0 Now Flying!
RV-6 #20916 N360EM "The Flyer"
http://www.mattsrv6.com - Matt's RV-6 Revitalization Log
Status: 300+ Hours - Full Flyer Mode!
Matt's Livermore Airport Live ATC Stream!
Check out the live ATC stream directly from my hangar at the Livermore
Airport.  Includes both Tower and Ground transmissions.  Archives too!
For entertainment purposes only.  http://klvk.matronics.com
________________________________  Message 2  _____________________________________
Time: 03:43:24 PM PST US
Subject: Re: Lycoming O-360 Fuel Flow Rate
You didn't say what your normal static RPM is for the engine/prop
combination you have but:
Are you sure your mixture control is going full rich when firewalled? Push
in full rich, disconnect from mixture lever and see if there is more travel
left. There is a mixture stop adjustment/assembly/parts on M/S family carbs.
"IF" it still has travel left, it is working as rigged, just not as you
would like.
Lycoming publishes expected fuel flow in the engine operations manual for
your particular model, but it seems if that 2400 RPM is full throttle/Full
mixture on your O-360/prop combo, it is low, very low. Something more like
76 lbs/hour at best power mixture which is like 12.5 gals/hour. If you
really are only using 9 gph (at) 2400 you are making like 110 BHP instead of
170+.
I wouldn't try taking off like that.
On Fri, Dec 18, 2015 at 5:38 PM, Matt Dralle <dralle(at)matronics.com> wrote:
> RV-6.  I've replaced the mechanical fuel pump and got a rebuilt 4-5
> carburetor, both of which were well over do for replacement/overhaul
> anyway.  I haven't put the cowling back on yet, but I did a static run up
> to about 2350-2400 and am seeing about 9gph, which seems low to me?
> pump on and saw about 21 GPH flow.  Is that considered "normal" or too low?
> Matt
> Matt Dralle
> http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel
________________________________  Message 3  _____________________________________
Time: 06:24:43 PM PST US
Subject: RE: Lycoming O-360 Fuel Flow Rate
You didn't say what manifold pressure or density altitude was but for sea l
evel to 3000ft at WOT 2400 rpm a 180 hp 360 should make about 130-140 Hp an
d fuel flow is roughly 0.075 - 0.08 gph per Hp. FAA regulations (23.955) re
quire 125% of 100% takeoff power fuel flow. 180 Hp * 0.08 gph = 24.4. 14.
4 * 1.25 = 18 gph so your fuel flow sounds sufficient.
The fuel flow curves for Lycoming 180 Hp OI-360 shows 135 Hp is about 10.6
gph give or take depending on mixture.
Deems Herring
> Date: Fri=2C 18 Dec 2015 14:38:37 -0800
RV-6.  I've replaced the mechanical fuel pump and got a rebuilt 4-5 carbur
etor=2C both of which were well over do for replacement/overhaul anyway.  I
haven't put the cowling back on yet=2C but I did a static run up to about
2350-2400 and am seeing about 9gph=2C which seems low to me?
- The Matronics LycomingEngines-List Email Forum -
http://www.matronics.com/Navigator?LycomingEngines-List
HTML Version:
Text Version:
Matt
would like.
170+.
> Matt
> Matt Dralle
Deems Herring
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> LycomingEngines-List All times are GMT - 8 Hours
