ADS-B with Avare's ADS-B Pro
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pulsar-List
lwheat2083
PostPosted: Mon Feb 22, 2016 2:49 pm    Post subject: ADS-B with Avare's ADS-B Pro Reply with quote
Off topic, kind of. Here is my situation: I am trying to build the Raspberry based Stratux ASB. Everything is done BUT I cannot get the Raspberry to respond correctly. I get 2 solid lights red and green. The green light on the ADSB radio comes on but immediately goes out. I have narrowed it down to the uploaded of the software to the Micro SD Card. I am using a MacBook Air. I have used the terminal method which works fine UNTIL you get to password and it claims cannot find file. I then tried the PiFiller and everything looks normal, does its thing and says it is ready insert in the Raspberry BUT there is no indication of anything happening except what is noted in the above. I open the file on the MicroSD card and I see 2 files, one is the .img file which is greyed out (cannot open) and a Boot file which is highlighted. I have no clue what the *&*^% is going on. HELP!!!! Cheers, Larry N853LW J250 Moses Lake, Washington USA
On Feb 8, 2016, at 9:33 AM, ronko(at)att.net (ronko(at)att.net) wrote:
Pulsar Friends,
Well I flew last Saturday with my ADS-B in set up. This time running the $2.49 ADS-B Pro app for Android. I ran the SDR (software defined radio USB module) from the tablet that wasn't fully charged to start (around 85%), and turned the screen intensity to full and left it always on and in a little over an hour I was down to 34% battery. It seemed to work great. Attached are screen shots of the Avare Map (note I am southeast of Chicago), the screen of the frames activity at one point during the flight and a picture of my set up showing antenna duct taped to the back of the passenger seat, the SDR, a OTG cable (with extra power in cord/connector that I didn't use) and my Samsung tablet. Landed with about 20% tablet battery left after a 1.7 hour flight, but when the tablet battery got to 34% I started blanking the tablet screen to see if the tablets battery would drain at a slower rate (still SDR powered) and indeed the battery didn't drain nearly as fast (still I liked having the screen on all the time).
I turned on the Avare option to display ADS-B weather, but there wasn't any in the 3 state area (which made it a great day to fly, but not a good day to show how the weather appears; Avare's app on Google shows how weather is displayed).
I plan on making a better antenna, specific for the ground base 978MHz reception (cable to make my antenna is coming from China) and will probably mount the antenna behind the passenger seat. Also am working on a simple cable solution to power both the tablet and SDR in flight (the Y cable I got supplies power to the SDR and not the tablet).
I just started working on a holder for the tablet and SDR which will utilize one of my RAM mounts (back up hand held radio is going to move somewhere else).
After this becomes more permanent a set up, I am wondering if I will need my Garmin 396 GPS anymore. I think I can get the functions and information that I use the 396 for, from the Avare app as it uses the tablet's GPS.
Best regards,
Ronko
N1037L
<Screenshot_2016-02-06-12-41-24.jpg><Screenshot_2016-02-06-13-01-29.jpg><Screenshot_2016-02-06-13-12-10.jpg><TabletOTGcableSDRwAnt.jpg>
- The Matronics Pulsar-List Email Forum -
http://www.matronics.com/Navigator?Pulsar-List
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pulsar-List All times are GMT - 8 Hours
