On rudder counterweight
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Glasair-List
mppalmer(at)aol.com
PostPosted: Sat Feb 27, 2016 8:51 am    Post subject: On rudder counterweight Reply with quote
IIRC, the factory said that the rudder was fairly stiff and they weren't too worried about flutter. So they didn't prescribe a formula or a "balance beam" approach, as they did with the ailerons and elevators. They just said to put a certain amount of weight in the front. Dace Kirk built a rudder for his Glasair III that has a large bottom section that protrudes below the fuselage. He used to be the owner of Phoenix Composites. If you can contact him, perhaps he can tell you how he "balanced" his rudder.
- The Matronics Glasair-List Email Forum -
http://www.matronics.com/Navigator?Glasair-List
snaproll(at)whidbey.com
PostPosted: Sat Feb 27, 2016 9:31 am    Post subject: On rudder counterweight Reply with quote
I will give him a call. Thanks so much!
Bob
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Glasair-List All times are GMT - 8 Hours
