Europra Jabiru builder
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Lightning-List
AirEupora
PostPosted: Wed Mar 09, 2016 4:07 pm    Post subject: Europra Jabiru builder Reply with quote
would like to talk with a Lightning builder or pilot regarding the setup that they are using with the Jabiru 3300 engine.
Prop pitch Degree????
IAS Kts ?????
Empty WT Pounds???
Normal Cruise RPM ????
Actual useful load. ????
Jetting for Carb
Needle Jet
Main Jet
Rick Stockton
707-330-1717
Europa XS, N120EJ
Whirlwind grn adjustable
- The Matronics Lightning-List Email Forum -
http://www.matronics.com/Navigator?Lightning-List
lbnpk3(at)gmail.com
PostPosted: Thu Mar 10, 2016 5:14 am    Post subject: Europra Jabiru builder Reply with quote
Prop: Sesinich WC 62 FK 56
Sesinich was very helpful on recommending the right prop and pitch for my plane and engine combo.
Airspeed= 140 mph at 4500’ with no wheel pants or fairings
RPM= 2750
Gross wt = 1250#
empty wt = 733#
useful load = 517#
Sorry no jet info
Larry
Esqual Jab 3300A
lbnpk3(at)gmail.com (lbnpk3(at)gmail.com)
On Mar 9, 2016, at 6:07 PM, AirEupora <AirEupora(at)sbcglobal.net (AirEupora(at)sbcglobal.net)> wrote:
--> Lightning-List message posted by: "AirEupora" <AirEupora(at)sbcglobal.net (AirEupora(at)sbcglobal.net)>would like to talk with a Lightning builder or pilot regarding the setup that they are using with the Jabiru 3300 engine.Prop pitch Degree????IAS Kts ?????Empty WT Pounds???Normal Cruise RPM ????Actual useful load. ????Jetting for CarbNeedle JetMain JetRick Stockton707-330-1717Europa XS, N120EJWhirlwind grn adjustableRead this topic online here:http://forums.matronics.com/viewtopic.php?p=453615#453615
n5pb(at)AOL.COM
PostPosted: Fri Mar 11, 2016 10:56 am    Post subject: Europra Jabiru builder Reply with quote
Rick,
Here are the numbers for my Lightning EAB with the Jab 3300.
Prop is Sensinich WC62FK58
Normal Cruise RPM: 2850
Normal Cruise speed: 147 mph (TAS)
Empty wt: 893 Lbs
Actual useful Load: 637 lbs (Max wt is 1530)
Needle Jet: 282
Main Jet: 250
Hope this helps
Bear
N82PB
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Lightning-List All times are GMT - 8 Hours
You cannot download files in this forum
