912 Oil Can / Lines
jareds(at)verizon.net
PostPosted: Wed Mar 23, 2016 12:37 pm    Post subject: 912 Oil Can / Lines Reply with quote
Looking for an inexpensive option for an oil can and lines for 912UL
build? Any ball park prices would be helpful.
Ace hardware doesnt carry that!!
Thx
Jared
earlaa(at)hotmail.com
PostPosted: Fri Mar 25, 2016 7:53 am    Post subject: 912 Oil Can / Lines Reply with quote
Are you referring to the sump tank?
Earl
Sent from my iPad
On Mar 23, 2016, at 2:43 PM, verizon <jareds(at)verizon.net> wrote:
Looking for an inexpensive option for an oil can and lines for 912UL build? Any ball park prices would be helpful.
Thx
Jared
PostPosted: Fri Mar 25, 2016 8:49 am    Post subject: 912 Oil Can / Lines Reply with quote
Yes i think so.  Im seeing guys using automotive tanks with cap for filling but cant find that kind on any of my auto sites
Earl
Sent from my iPad
> Thx
> Jared
jack(at)comconn.com
PostPosted: Sat Mar 26, 2016 5:00 am    Post subject: 912 Oil Can / Lines Reply with quote
Not sure if this will help, but you might do a google search of "dry
sump oil tank"
They're not common on cars, but my norton motorcycle has a
(vintage=expensive) one..
$.02
-Jack
On 3/26/2016 2:03 AM, Kitfox-List Digest Server wrote:
Time: 09:49:18 AM PST US
Subject: Re: 912 Oil Can / Lines
filling but cant find that kind on any of my auto sites On Mar 25, 2016
> Earl
> Sent from my iPad
>> Thx
>> Jared
KeysFox
PostPosted: Sun Mar 27, 2016 9:35 am    Post subject: 912 Oil Can / Lines Reply with quote
If you attend one of the 912 Rotax courses, there is mention that the 912
oil header tank's inlet tube , which goes thru the tank top, is designed
to swirl the hot engine oil downward around the side wall of the header
tank to help with cooling the oil. There are several other design
features in the OEM header tanks that may not be present in an after
market tanks intended for a different engine and installation application.
How important? I do not know.
I certainly do not hold myself out as having significant expertise in this
arena.
BJ Kitfox IV 1050 Warp Drive 3 blade, 912 80 hp.
sump oil tank"
$.02
-Jack
>> Earl
>> Sent from my iPad
>>> build?
>>> Thx
>>> Jared
B Jones
N154K
443-480-1023
Dick Maddux
PostPosted: Mon Mar 28, 2016 9:54 am    Post subject: 912 Oil Can / Lines Reply with quote
Jared
 You absolutely do not want to "jury rig " an oil tank for your 912. You are asking for engine failure. The tank is designed for that engine and it has an internal foam screen,proper capacity, cooling, etc. Do it right, attend a class or two ( I have gone to 4) and learn about this engine.
You have Lockwood,CPS,LEAF,and So Mississippi Light Aircraft all available to you.
 Dick Maddux
 912UL
Sent from Samsung tablet
