TeamGrumman-List Digest: 3 Msgs - 05/04/16
aksnarek(at)gmail.com
PostPosted: Thu May 05, 2016 12:39 am    Post subject: TeamGrumman-List Digest: 3 Msgs - 05/04/16 Reply with quote
I use aviation dual seal door seal. Works a treat and seals out noise.
On 5 May 2016, at 17:03, TeamGrumman-List Digest Server <teamgrumman-list(at)matronics.com> wrote:
Today's complete TeamGrumman-List Digest can also be found in either of the
of the TeamGrumman-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 16-05-04&Archive=TeamGrumman
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 16-05-04&Archive=TeamGrumman
TeamGrumman-List Digest Archive
Total Messages Posted Wed 05/04/16: 3
Today's Message Index:
1. 08:26 AM - Re: Canopy seals (Dennis Cheever)
2. 09:07 AM - Re: Canopy seals (Discover)
3. 09:36 AM - Re: Re: Canopy seals (FLYaDIVE)
Time: 08:26:07 AM PST US
Subject: Re: Canopy seals
That makes sense and is what Ken demonstrated at his wrench bending weekend
in Phoenix. So just get a roll of white felt and apply it at the back edge
of the canopy. Do you have reccomendations based on experience for width and
thickness for the best seal?
Time: 09:07:04 AM PST US
http://www.campbells.org/Airplanes/airplane_canopyseals.html
http://www.mcmaster.com/#felt/=y51onl
Try 2" wide by 1/4" adhesive backed
http://forums.matronics.com/viewtopic.php?p=455870#455870
Time: 09:36:44 AM PST US
Subject: Re: Re: Canopy seals
Thanks for the info Discover:
I have always used Wool Weather Stripping from the Aviation Aisle at Lowes.
It does not have the self-stick backing so you then have to move down to
the Aviation Floor Covering Aisle and pick up Double Sided Carpet Tape.
Get the one that has the fiber reinforcement, it is stronger and easier to
work with. The job can be done without removing the canopy. And the carpet
tape allows for total coverage of the area. The NON-Sticky Backed wool
weather striping is much more flexible for side-to-side adjustments when
placing it down. I mention this because the canopy has compound curves
that must be matched for a flat lay-up. This is what I have found to be the
Least Expensive and Easiest to do.
McMaster Carr is a great company for the hard to find items, but they
CHARGE for their convenience.
Barry
"Chop'd Liver"
