[RV Builders] Re: Tru-Trak roll servo in 6/6A wing
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Avionics-List
gyoung
PostPosted: Mon May 16, 2016 10:41 am    Post subject: [RV Builders] Re: Tru-Trak roll servo in 6/6A wing Reply with quote
I'm guessing you've checked with Tru-Trak? They seemed to try hard to accommodate all installs back then. When I was planning to add the roll servo to my -6 I thought I'd mount it in the wing and use the -7 mount. I don't remember any one talking about problems with it but did not investigate it that deeply as I decided to go with the under seat mount. If it helps I don't see any reason why you couldn't mount it under either seat. You could also consider the Navaid approach and mount the servo in the wingtip with a long pushrod to the bellcrank. I've got the mount and pushrod from my 1st RV-6 if you want to see how that worked.
Greg Young
- The Matronics Avionics-List Email Forum -
http://www.matronics.com/Navigator?Avionics-List
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Avionics-List All times are GMT - 8 Hours
