Fuel tank vent line
Kitfox Jack
PostPosted: Wed Jun 01, 2016 6:27 am    Post subject: Fuel tank vent line Reply with quote
Is it a good idea to replace the tygon tubing vent line from the header tank to the wing tank with a good quality 1/4 fuel injection hose from Carquest?
Envoyé par Courrier pour Windows 10
lcfitt3(at)gmail.com
PostPosted: Wed Jun 01, 2016 10:10 am    Post subject: Fuel tank vent line Reply with quote
I like the transparent line for a visual second source of fuel level.  I recently flew a  long leg where on descent to pattern altitude for landing,  the low fuel light came on.  A glance at the tygon vent confirmed the low fuel sensor warning.  I liked the information for the reassurance that the warning system was functioning as designed.  That is just me, though.
Lowell Fitt
IV-1200 On Jun 1, 2016 7:44 AM, "Rosane Baule" <jvoynaud(at)outlook.com (jvoynaud(at)outlook.com)> wrote:
Guy Buchanan
PostPosted: Wed Jun 01, 2016 11:50 am    Post subject: Fuel tank vent line Reply with quote
Believe it or not I use the blue transparent Bing alcohol resistant fuel line nearly everywhere. It's worked great so far. (I do replace it yearly, at annual, though.)
Guy Buchanan
Ramona, CA
Kitfox IV-1200 / 912-S / Warp 3cs / 600 hrs
Glider pilot, too
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
Kitfox Jack
PostPosted: Wed Jun 01, 2016 6:06 pm    Post subject: Re: Fuel tank vent line Reply with quote
I had the blue fuel line from aircraft spruce on for a while but it cracked and spilled the gas inside the cockpit. I should have changed it yearly, like you said.
