Interfacing MX-20 (or GMX-200) with NavWorx ADS600-B
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Avionics-List
gyoung
PostPosted: Wed Jun 08, 2016 8:23 am    Post subject: Interfacing MX-20 (or GMX-200) with NavWorx ADS600-B Reply with quote
Here’s a link to some pictures of my MX-20 set-up screens. There are also some in use shots of the traffic displays on my 430W, MX-20 and 796.
[url=https://onedrive.live.com/redir?resid=1421064BFC892DA1!14381&authkey=!AOC2b8m59Vt5FO8&ithint=folder%2cjpg]https://onedrive.live.com/redir?resid=1421064BFC892DA1!14381&authkey=!AOC2b8m59Vt5FO8&ithint=folder%2cjpg[/url]
Greg
From: owner-avionics-list-server(at)matronics.com [mailto:owner-avionics-list-server(at)matronics.com] On Behalf Of bigdog(at)bentwing.com
Sent: Wednesday, June 08, 2016 10:03 AM
To: avionics-list(at)matronics.com; rv-list <rv-list(at)matronics.com>
Subject: RE: Avionics-List: Interfacing MX-20 (or GMX-200) with NavWorx ADS600-B
Ralph,
I installed it with my MX-20. I've since reworked my panel and replaced it with a 796 in an AirGizmo dock. But I've still got some pictures of the settings. The relevant ones are:
Misc Setup: GDL 90 UAT Radio = Disp Only, GDL 90 Code Edit = Enabled
External Data Sources: UAT Traffic/Data Link Source = Port 4 (for me)
Enable/Disable Function: Traffic = Enabled, FIS Data Link = Enabled
Also make sure you set the Broadcast ICAO Address. I don’t know which screen in setup. It’s the 8 digit hex-looking Mode-S code that translates to your N-number. For whatever reason I put my N-number in it and fought an error message for a while.
I got traffic and Metars on the MX-20 but only traffic on the 430W. I’m very disappointed with the display on the 430W. Since Garmin doesn’t play nice with others Navworx can only feed it traffic and you don’t get all the capability of the 430W that it has with say a GDL-88. I love the display on the 796 but unfortunately Navworx doesn’t support it either, again because Garmin doesn’t play nice and they haven’t reverse engineered it. So I’m feeding it from a GDL-39 works well despite being totally separate.
Good luck. If needed I can send the pics of the setup screens.
Greg Young
- The Matronics Avionics-List Email Forum -
http://www.matronics.com/Navigator?Avionics-List
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Avionics-List All times are GMT - 8 Hours
