AutoZone gas spring working well
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Glasair-List
mppalmer(at)aol.com
PostPosted: Thu Jun 16, 2016 3:07 pm    Post subject: AutoZone gas spring working well Reply with quote
Following up on my AutoZone "Mighty Lift!" brand lift strut on the copilot-side canopy. (Of an early Glasair II.)
It works fine.
The stroke is 3/4 of an inch shorter than the OEM gas spring. That means that the canopy doesn't open quite as much as originally. (Like, 5 to 10 degrees at the top?) If it bothers me enough, I might make a hooked style metal extension for the bracket on the canopy. That would hold the canopy open more and would also put a "down force" on the canopy when the canopy is closed. (Instead of the up force as now.)
Mike Palmer <><
- The Matronics Glasair-List Email Forum -
http://www.matronics.com/Navigator?Glasair-List
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Glasair-List All times are GMT - 8 Hours
