Need recommendation for Lycoming rebuilder near Ohio
Jay Herron
PostPosted: Fri Jul 29, 2016 4:25 am    Post subject: Need recommendation for Lycoming rebuilder near Ohio Reply with quote
My 801 has a Lycoming O-360 that needs a new oil seal installed behind the prop. It looks like I would need to completely disassemble it to install. It has 1500 hours since overhaul and 3700 hours TT. Anyhow, can someone recommend a mechanic/rebuilder in Ohio? I don't need it certified.
usnret(at)3riversdbs.net
PostPosted: Fri Jul 29, 2016 7:44 pm    Post subject: Need recommendation for Lycoming rebuilder near Ohio Reply with quote
Crank seal is replaced by removing the prop,,, pull the old seal,,
remove the spring from the new seal, using the seal install tool, it is
stretched over the prop flange ,,,,,,,,, and A&P can do it in about
Thirty minutes after the prop is pulled.
Tom
