ftyoder(at)yoderbuilt.com Guest
Posted: Sat Jul 30, 2016 6:46 pm Post subject: September Trip |
You might see if you can pry the joggle lip away from the bottom half in order to confirm the Hysol bond failed. If it has, you might want to inject Hysol back into the the joint. Are you going to add some fiberglass overlay to the outside also? I believe that the crack will reappear if you don't.
From: owner-kis-list-server(at)matronics.com [mailto:owner-kis-list-server(at)matronics.com] On Behalf Of Galin Hernandez
Sent: Saturday, July 30, 2016 5:35 PM
To: kis-list(at)matronics.com
Subject: Re: September Trip
All; I went to the hangar today, wedged my big "rear" into the inside of the cockpit and got a good look at where the separation is but from the inside. As OC speculated, it is exactly on the seam between the upper 1/2 and bottom 1/2 of the fuselage assembly. You can feel the two halves separating right along the seam. It looks like I will have to reinforce the area but glassing over the seam "lip" is going to be interesting. I am thinking of 5 plies of 9oz fiberglass using West Marine epoxy resin along the inside of the fuselage with about 3" of overlap. Does this sound about right or am I missing something?
On Fri, Jul 29, 2016 at 9:31 PM, Galin Hernandez <galinhdz(at)gmail.com (galinhdz(at)gmail.com)> wrote:
Quote: | Kent; I will let you know as the date/time gets closer. I hope to have the fiberglass repair to the fuselage done in the next week so I can make the trip and not have to postpone it.
On Fri, Jul 29, 2016 at 11:34 AM, Kent Pyle <kentpyle(at)iland.net (kentpyle(at)iland.net)> wrote:
Quote: | We are looking forward to seeing you. bed and breakfast!! and another meals you might be here for. Kent
Please keep us posted as to date and time.
Sent: Tuesday, July 26, 2016 7:22 AM
Kent; We are in the early planning stages of the trip but we are planning to fly into KGLY. It actually works very well for us to spend the night on our way to Grand Forks.
On Mon, Jul 25, 2016 at 10:47 AM, Kent Pyle <kentpyle(at)iland.net (kentpyle(at)iland.net)> wrote:
Quote: | Mary Anne and I are hoping you can stop by. We live just across the street from the airport Kent
Sent: Saturday, July 23, 2016 5:44 PM
OK, Expect us at KGLY around Sep 5th. I will coordinate more exact details as the date gets closer. It almost right on our route.
On Sat, Jul 23, 2016 at 12:48 PM, Kent Pyle <kentpyle(at)iland.net (kentpyle(at)iland.net)> wrote:
Quote: | Galin, please stop by Clinton, MO 64735 GLY. I have bed and breakfast Kent
Sent: Friday, July 22, 2016 7:55 PM
I've seen both you and your KIS but more importantly Bev and I have never met the fabulous Millie. Be happy to have you drop by if it works on your schedule.
Dave Tate
From: Galin Hernandez <galinhdz(at)gmail.com (galinhdz(at)gmail.com)>
To: "kis-list(at)matronics.com (kis-list(at)matronics.com)" <kis-list(at)matronics.com (kis-list(at)matronics.com)>
Sent: Friday, July 22, 2016 5:24 PM
Subject: KIS-List: September Trip
FWIW Millie & I will be making a long trip in our KIS-4 airplane. We plan to fly from St. Augustine, FL to Ft. Campbell, KY to Des Moines, IA to Grand Forks, ND to Chicago, IL to Dayton, OH to Knoxville, TN to Charlotte, SC and back to St Augustine, FL starting on Sept 1st 2016 and ending sometime around September 22nd. If anybody is available we would really like to meet up with any KIS owners/builders that live close to our planned route. I have attached a .jpg of our planned route which as of right now is VERY open to change.
Virus-free. www.avast.com
| - The Matronics KIS-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
hansoncp(at)netnitco.net Guest
Posted: Sat Jul 30, 2016 7:32 pm Post subject: September Trip |
I'd give it three layers of four plies stepping down each layer about 1/2 inch in size. Covering all the available space at the joggle. This should help dampen the vibration some. Also as Tim has stated, try to inject some adhesive into the outer separation.
galinhdz(at)gmail.com Guest
Posted: Sun Jul 31, 2016 4:03 am Post subject: September Trip |
I will try to pry the lip apart some more but it hasn't separated very much and the two sides are basically still touching each other. I may not be able to inject anything between the two sides. Maybe make some very watery solution and let it seep into the crack might work. Then use 12 plies as Ed recommends for the actual repair and a few plies on the outside as well. This will take away from the esthetics, but safety trumps esthetics every time.Â
On Sat, Jul 30, 2016 at 11:30 PM, Ed Hanson <hansoncp(at)netnitco.net (hansoncp(at)netnitco.net)> wrote:
[quote] I'd give it three layers of four plies stepping down each layer about 1/2 inch in size. Covering all the available space at the joggle. This should help dampen the vibration some. Also as Tim has stated, try to inject some adhesive into the outer separation.
