[RV Builders] (unknown)
dan(at)weyant.net
PostPosted: Tue Aug 09, 2016 5:23 am    Post subject: [RV Builders] (unknown) Reply with quote
Ralph,
I’m running an IO-320 in my RV-9A.
I initially had some issues with my #1/#3 side running hotter on #1 than #3.  I started slowly cutting my block off plate away.  I eventually wound up removing it entirely.
Obviously each install is a little different.
When I had one it was about 3 inches long (covered about the lower ½ of the #1.  And about 2 inches high, rougly rectangle shapped
I notice a big difference between cruise and climb.  I think it is mostly related to airspeed.  Slower airspeed and full power I have to really watch my CHT’s.  I usually run in the high 300’s during climb.  At cruise leaned out I run about 350-370.
-Dan
From: RV7A(at)yahoogroups.com [mailto:RV7A(at)yahoogroups.com]
Sent: Tuesday, August 09, 2016 8:11 AM
To: rv-list <rv-list(at)matronics.com>; RV7 Yahoo list <RV7A(at)yahoogroups.com>
Subject: [RV Builders] (unknown)
For those of you running a four cylinder:
What does your #1 block off plate look like?
What kind of shape is it?
What dimensions at each end?
How well does it control / regulate the CHT balance for #1 and #3?
Do you notice differences between climb attitude and level flight attitude?
My #2 and #4 side seems to be pretty well balanced - even with the oil cooler opening up behind the #4. My #1 and #3 side still has the #3 CHT a little higher than I want it consistently and I have been fiddling with the size/shape of the #1 baffle in an effort to get a better level attitude balance. I have the spacer washer between the #3 baffle wraparound and the cylinder head - but I also have the openings for the muffler/heater air back there at the #3 area as well.
I'm trying to get a sense of what is working for folks out there - how big/small, what shape, and how effective.
I have installed the 'Turbo' shrouds at the suggestion of my FI vendor to help balance the injector flows - that seems to be working quite well!
Ralph Capen
Aerosport XP IO360B1F6 with LASAR ignition and Airflow Performance injection
__._,_.___
Posted by: "Ralph E. Capen" <recapen(at)earthlink.net (recapen(at)earthlink.net)>
Reply via web post
Reply to sender ([email]recapen(at)earthlink.net?subject=Re%3A%20%28no%20subject%29[/email])
Reply to group ([email]RV7A(at)yahoogroups.com?subject=Re%3A%20%28no%20subject%29[/email])
Start a New Topic
Messages in this topic (1)
[img]https://s.yimg.com/ru/static/images/yg/img/megaphone/1464031581_phpFA8bON[/img]
Have you tried the highest rated email app?
With 4.5 stars in iTunes, the Yahoo Mail app is the highest rated email app on the market. What are you waiting for? Now you can access all your inboxes (Gmail, Outlook, AOL and more) in one place. Never delete an email again with 1000GB of free cloud storage.
Want more RV news? Sign up for the RV Builder's Hotline. It's free!
http://rvbuildershotline.com
Visit Your Group
• Unsubscribe ([email]RV7A-unsubscribe(at)yahoogroups.com?subject=Unsubscribe[/email]) • Terms of Use
[img]http://geo.yahoo.com/serv?s=97359714/grpId=17152007/grpspId=1705340085/msgId=7909/stime=1470748430[/img]
[img]http://y.analytics.yahoo.com/fpc.pl?ywarid=515FB27823A7407E&a=10001310322279&js=no&resp=img&cf12=CP[/img]
__,_._,___
www.avast.com
PostPosted: Tue Aug 09, 2016 5:31 am    Post subject: [RV Builders] (unknown) Reply with quote
Thanks Dan!
