Belleville Washers and IO-240 Oil Drain Plug
bakerocb
PostPosted: Wed Aug 17, 2016 1:17 pm    Post subject: Belleville Washers and IO-240 Oil Drain Plug Reply with quote
8/17/2016
Hello Fellow KIS TR-1 Builders and Pilots, I am seeking some information that I hope you will be able to help me with.
1) If you are using 3/4 inch inside diameter Belleville washers to provide the friction for your nose landing gear swivel I would appreciate knowing what washers you are using and any comments on their use. Here are some potential candidates:
http://www.mcmaster.com/#belleville-disc-springs/=13ro6i2
2) I would like to know the diameter and thread count for the oil drain plug on the Continental IO-240 BXB engine. Continental part number is either:
PN: 656169 at US $437.35 for each engine ...... B1B through ....... B31B
or
PN: 636376 at US $113.06 each for engine ....B32B
See here:
http://www.continentalmotors.aero/Support_Materials/Publications/Illustrated_Parts_Catalog/
I believe that the diameter and thread count for both of these part numbers is identical. I am seeking this information so that I can buy a Saf-Air oil quick drain plug for my IO-240 B9B engine. See here:
http://www.aircraftspruce.com/catalog/eppages/safairsump.php?clickkey=165469
Thanks for your help.
OC
'O C' Baker says "The best investment you can make is the effort to gather and understand information."
galinhdz(at)gmail.com
PostPosted: Thu Aug 18, 2016 3:16 pm    Post subject: Belleville Washers and IO-240 Oil Drain Plug Reply with quote
OC, The nose wheel on my TR-4 also uses 3/4" ID Belleville washers. As far as I remember the FASTENAL SKU is 33358 with a UNSPSC number of 31161825 and I have had no issues with them. I hope this helps.
www.fastenal.com
On Wed, Aug 17, 2016 at 5:16 PM, Owen Baker <bakerocb(at)cox.net (bakerocb(at)cox.net)> wrote:
or
See here:
OC
