more spare parts
dlm34077
PostPosted: Mon Sep 05, 2016 8:54 am    Post subject: more spare parts Reply with quote
Also in the spare parts are an O ring kit for brakes and prop, extra fuel drain for leaking tank drain and several ready to go master cylinders for the brakes and a small quantity of 5606 and the means to fill.
You as manufacturer are entitled to state an MEL for the aircraft in order to have aboard items not perhaps allowed separately in the hangar and to specifically state the aircraft requirements for flight: for example operational brakes are an item required for safety of flight or at least a single operational EFIS or at least a single operational battery. Although the MEL normally applies to the large manufacturers to ensure enough equipment is operatonal to safely fly the aircraft, the MEL can be used to document the requirements when multiple pilots operate your aircraft.
www.avast.com
