PCU 5000 able to command low rpm (<1700rpm)?
TimRVator(at)comcast.net
PostPosted: Mon Sep 19, 2016 12:34 pm    Post subject: PCU 5000 able to command low rpm (<1700rpm)? Reply with quote
I'm considering replacing my MT prop governor. One thing I do like
about the MT governor is you can pull the prop control back during
engine out practice and the governor slows the engine way down (which
extends glide).
I understand (from owner comments and Hartzell tech support) that the
Hartzell governor's minimum governing speed is about 1700 rpm. I'm
interested in learning what minimum governing speed folks have seen on
aircraft flying with the PCU 5000X.
Tim Lewis -- HEF (Manassas, VA)
A&P
RV-6A N47TD -- 1104 hrs - sold
RV-10 N31TD -- 740 hrs
carl.froehlich(at)verizon
PostPosted: Mon Sep 19, 2016 1:45 pm    Post subject: PCU 5000 able to command low rpm (<1700rpm)? Reply with quote
That is about the RPM I see (RV-8A and RV-10) with the PCU-5000X.
Carl
On Sep 19, 2016, at 4:31 PM, Tim Lewis <TimRVator(at)comcast.net> wrote:
I'm considering replacing my MT prop governor. One thing I do like about the MT governor is you can pull the prop control back during engine out practice and the governor slows the engine way down (which extends glide).
I understand (from owner comments and Hartzell tech support) that the Hartzell governor's minimum governing speed is about 1700 rpm. I'm interested in learning what minimum governing speed folks have seen on aircraft flying with the PCU 5000X.
A&P
PostPosted: Mon Sep 19, 2016 5:54 pm    Post subject: PCU 5000 able to command low rpm (<1700rpm)? Reply with quote
Thanks, Carl.
I want to make sure I understand your reply correctly. I do my runups
at 1800. If I pull the prop control back during runup, the MT
governor/prop will slow the engine way down -- probably below 1000 rpm.
Certainly well below 1700 rpm. Are you telling me that with the PCU
5000, if pull the prop control all the way back (at runup, for example),
your experience is the PCU5000 won't slow the engine below 1700 rpm?
Thanks very much for your insights. I appreciate it.
Tim Lewis
A&P
Carl Froehlich wrote on 9/19/2016 5:43 PM:
Carl
> A&P
PostPosted: Mon Sep 19, 2016 6:28 pm    Post subject: PCU 5000 able to command low rpm (<1700rpm)? Reply with quote
I don't recall how far it will pull down the RPM - I only pull the prop
until a get a slight drop to make sure the governor is functioning. I was
told (correctly or incorrectly) deep run up cycles are hard on props.
Carl
PostPosted: Mon Sep 19, 2016 6:46 pm    Post subject: PCU 5000 able to command low rpm (<1700rpm)? Reply with quote
Carl,
I was told the same.
If you get a chance, perhaps you can test this: At 1000 rpm idle, can
you pull the prop control and see if the prop governor will further slow
the engine rpm. If so, that's the info I'm looking for.
VR
A&P
Carl Froehlich wrote on 9/19/2016 10:26 PM:
Carl
Mauledriver(at)nc.rr.com
PostPosted: Tue Sep 20, 2016 3:20 am    Post subject: PCU 5000 able to command low rpm (<1700rpm)? Reply with quote
On a similar note, I avoid running at or below 1000 rpm to avoid lead fouling, which I am led to believe can happen even when fully leaned.
While attending Lycoming Engine School, I followed up with the instructor after his lead fouling discussion and came away with the understanding that lead build-up will occur anytime combustion chamber temperatures drop below a certain point.  He emphasized that it happens very quickly based on some testing he was familiar with.  He mentioned that that the practice of pulling the power off at touchdown and leaving it there during the rollout is enough to form visible deposits.  By the same token, heating things up above the critical temperature soon after will cause most, but not all of those new deposits to quickly evaporate away.
This write-up from Shell seems to support that thinking.
As a result of the same thinking,  I've never practiced engine out descents with the power pulled all the way and the prop slowed anywhere near 1000 rpm.
This former fixed pitch jockey handles the prop cycling task by setting the power around 1500 rpms before cycling the prop.  During the cycle, the rpm drop just hits 1000 rpms as I move the control forward.   And I try to not to imitate what I've seen some CFIs do by slamming the prop control this way and that.  On my engine a slower steady hand will do.
I've never been told that it's hard on the prop and don't believe it is.  I have been told that I'm both checking function and forcing some warm oil thru the controller so that it performs as expected during takeoff.  Now I'm thinking the main task is just to make sure it works without spraying oil all over the place but honestly just don't really know.  I just do it.
Bill "glider guider at  heart that has learned to love that big 'ol 540" Watson
N215TG
--> RV10-List message posted by: Tim Lewis <TimRVator(at)comcast.net> (TimRVator(at)comcast.net)
Thanks, Carl.
I want to make sure I understand your reply correctly. I do my runups at
1800. If I pull the prop control back during runup, the MT governor/prop
Tim Lewis
www.avast.com
PostPosted: Wed Sep 21, 2016 12:18 pm    Post subject: PCU 5000 able to command low rpm (<1700rpm)? Reply with quote
Well shoot fire Tim, on today's hop I did not remember what you asked. This is what I did it if helps. At the end of the 1800 RPM run up I pulled the prop all the way out. The governor brought RPM down to below 1100 RPM.
Should do another hop Friday so I'll do your test then.
Carl
[quote] On Sep 19, 2016, at 10:45 PM, Tim Lewis <TimRVator(at)comcast.net> wrote:
Carl,
If you get a chance, perhaps you can test this: At 1000 rpm idle, can you pull the prop control and see if the prop governor will further slow the engine rpm. If so, that's the info I'm looking for.
VR
A&P
> Carl
PostPosted: Wed Sep 21, 2016 3:03 pm    Post subject: PCU 5000 able to command low rpm (<1700rpm)? Reply with quote
Thanks, Carl. The data point you took today is very helpful to my . I
appreciate it.
A&P
Carl Froehlich wrote on 9/21/2016 4:14 PM:
Carl
> Carl,
> VR
> Tim
> A&P
>> Carl
