Installing the "Red cube"
trigo(at)mail.telepac.pt
PostPosted: Wed Nov 30, 2016 10:43 am    Post subject: Installing the "Red cube" Reply with quote
Guys
Those of you who installed the fuel flow sensor (aka the "red cube") below the engine, between the throttle body and the fuel distribution "spider", you had to order a small fire sleeved fuel line, right?
Can you please tell me where did you order it, and the specifications (length, diameter and type & size of the fittings) of that extra fuel line?
Carlos
Lenny Iszak
PostPosted: Wed Nov 30, 2016 11:30 am    Post subject: Re: Installing the Reply with quote
You'll need two lines, one from the servo to redcube and the other from the redcube to the spider. The dimensions depend on how and where you are mounting the redcube. Some fuel line makers can chop your original fuel line in two and put two new ends on them. If you already have your fuel line that might be a good option.
I got integral firesleeved hoses from Stratoflex, but I think the ceramic fibers in the red firesleeve keeps the hose a bit cooler than the brown integral silicone.
Lenny
flying-nut(at)cfl.rr.com
PostPosted: Wed Nov 30, 2016 11:31 am    Post subject: Installing the "Red cube" Reply with quote
I have lots of JIC fittings for the braided steel/teflon hose. So, I
cut the kit hose from the mechanical fuel pump to the fuel servo. Bad
move. The teflon liner wasn't the correct size for my fittings so I
made up two hoses and used the firesleeve from the kit hose. I mounted
my FF sender on a plate attached to the lower, fwd engine mount tube
with Adel clamps. I wanted as much straight in/out as I could get.
Different from the vertical hose you want, but the idea is the same.
You can get the braided/teflon hose with 37* fittings at most any
hydraulic shop ..... tell them it's for a race car or airboat .... they
don't like to hear 'airplane'.
Linn
On 11/30/2016 1:39 PM, Carlos Trigo wrote:
Guys
Carlos
TimRVator(at)comcast.net
PostPosted: Thu Dec 01, 2016 7:54 pm    Post subject: Installing the "Red cube" Reply with quote
I made my own two hoses (servo to cube, cube to spider):
4 ea Eaton Hose Fitting F66000-4 (ACS part 05-01320)
Aeroquip clamps for hose ends, and to clamp firesleeve to red cube -
Aeroquip Clamp 900591B-2C, -1C, and -3C.
Aeroquip Firesleeve AE102-8 (5 feet)
Aeroquip Firesleeve AE102-24 (1 foot)
Aeroquip Hose #666-4 (6 feet).
Aeroquip publishes instructions on how to assemble.
Tim Lewis -- HEF (Manassas, VA)
A&P
RV-6A N47TD -- 1104 hrs - sold
RV-10 N31TD -- 740 hrs
Carlos Trigo wrote on 11/30/2016 10:39 AM:
Guys
Carlos
PostPosted: Fri Dec 02, 2016 3:22 am    Post subject: Installing the "Red cube" Reply with quote
Thanks a lot Tim
That's exactly the information I needed!
Cheers
Carlos
-----Mensagem original-----
De: owner-rv10-list-server(at)matronics.com
[mailto:owner-rv10-list-server(at)matronics.com] Em nome de Tim Lewis
Enviada: Friday, December 2, 2016 3:54 AM
Para: rv10-list(at)matronics.com
Assunto: Re: Installing the "Red cube"
4 ea Eaton Hose Fitting F66000-4 (ACS part 05-01320) Aeroquip clamps for
hose ends, and to clamp firesleeve to red cube - Aeroquip Clamp 900591B-2C,
-1C, and -3C.
A&P
Guys
Carlos
