MT P860-3 Prop Gov fail.
Goto page Previous  1, 2, 3
PostPosted: Wed Nov 16, 2016 6:54 am    Post subject: MT P860-3 Prop Gov fail. Reply with quote
If I understand what you posted, if your serial number is not on the service bulletin then you are good to go...Good Luck
On Wed, Nov 16, 2016 at 6:40 AM, bob88 <marty.crooks(at)comcast.net (marty.crooks(at)comcast.net)> wrote:
--> RV10-List message posted by: "bob88" <marty.crooks(at)comcast.net (marty.crooks(at)comcast.net)>
Where can I access the SB on this? The Van's website directs to MT website but the list of MT SBs doesn't seem to include this one.
http://forums.matronics.com/viewtopic.php?p=462641#462641
br> fts!)
r> > com" rel="noreferrer" target="_blank">www.aeroelectric.com
w.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersbooks.com
p.com" rel="noreferrer" target="_blank">www.homebuilthelp.com
e.com" rel="noreferrer" target="_blank">www.mypilotstore.com
" rel="noreferrer" target="_blank">www.mrrace.com
          -Matt Dralle, List Admin.
FORUMS -
WIKI -
b Site -
Thank You,
Craig RufiEmail craigr60(at)gmail.com (craigr60(at)gmail.com)
Cell 805 402-6480
jrlark
PostPosted: Wed Nov 16, 2016 3:59 pm    Post subject: MT P860-3 Prop Gov fail. Reply with quote
Bob88 try this link http://www.mt-propeller.com/en/entw/serviced.htm or
google MT prop service bulletins. I just tried it and they are there.
Rick
C-GDMH
Kelly McMullen
PostPosted: Wed Nov 16, 2016 6:13 pm    Post subject: MT P860-3 Prop Gov fail. Reply with quote
Note:  Ignore the languag about higher compression and electronic ignition. IIRC none of the failures had either feature. If your serial number is there, regardless of model, contact MT-USA. Even if your serial number is anywhere close, talk to them. My model was not  included, but my serial number was. they said send it in. It cost me shipping both directions, but no charge to modify to latest design parts. It was worth it for peace of mind.
-sent from the I-droid implanted in my forearm
On Wed, Nov 16, 2016 at 4:56 PM, Sandra & Rick <jrlark(at)bmts.com (jrlark(at)bmts.com)> wrote:
[quote]--> RV10-List message posted by: "Sandra & Rick" <jrlark(at)bmts.com (jrlark(at)bmts.com)>
Rick
C-GDMH
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
tsts4
PostPosted: Fri Dec 23, 2016 2:09 pm    Post subject: Re: MT P860-3 Prop Gov fail. Epilogue..... Reply with quote
So it's been almost 5 months since my prop gov self destructed and shelled the engine on my RV-10, Finally got it back from BPE this past Wed and got it mounted today:
Now just a few things to tidy up (fuel and oil lines, throttle body, air box, exhaust, primary alternator, starter, sensors, p-leads, electrical wiring, control cables, ring gear, prop, prop governor, and baffles) and we're back in business.
It was supposed to be on the in the paint shop right now getting finishing touches on it's paint job, but I had to give up my slot. Luckily I was able to swap with the guy behind me so I'll get it painted in March.
Todd Stovall
aka "Auburntsts" on EAA and VAF
RV-10 N728TT -- Flying
Page 3 of 3
