Allegro-List Digest: 1 Msgs - 01/05/17
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Allegro-List
doug(at)allegrolsa.com
PostPosted: Fri Jan 06, 2017 8:50 am    Post subject: Allegro-List Digest: 1 Msgs - 01/05/17 Reply with quote
Bill,
Another good question. Yes, you can remove the center console. Underneath
there is the fuel sending unit. It is held in place by four set-in bolts.
Remove the nuts and the entire white unit can be removed...take care to not
bend the float rod and float when you remove it. This gives another larger
hole for access. In addition, you will want to remove the fuel feed line
going to the flooring under the front floor boards. When you remove this,
the entire rod insert and attached strainer will come out as well. In
addition, you will want to remove the bottom fuel drain plug, then coat both
the bottom and fuel feed threads that remain in the tank with a grease to
prevent slosh coating "fowling" the threads. Please let me know if you need
additional information.
Doug
Douglas Hempstead
LSA America, Inc.
PO Box 490
Littleton, NC 27850
252-586-1200 - office
252-586-1203 - fax
www.allegrolsa.com
- The Matronics Allegro-List Email Forum -
http://www.matronics.com/Navigator?Allegro-List
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Allegro-List All times are GMT - 8 Hours
