Static System Icing
kearney
PostPosted: Mon Jan 30, 2017 1:00 pm    Post subject: Static System Icing Reply with quote
Hi
A few days ago I was flying for a couple of hours in -7c wx (19F for those south of the 49th). Everything was uneventful until I was on a downwind to land when my static line became blocked.
Fortunately my annual was only a couple of days away so I checked things out when I had everything opened up for inspection. I found a 1/4" column of water in the static line low point in the tail cone. As it was well below freezing there the line must have frozen thereabouts.
A quick blast of air (from the panel end of the line) and the water was gone.
I thought I'd mention this as something to watch for.
Cheers
Les
Dave Saylor
PostPosted: Mon Jan 30, 2017 5:29 pm    Post subject: Static System Icing Reply with quote
Yeah, it's bad enough dealing with erroneous information ourselves, but in these days of powerful autopilots, you have to make sure it doesn't get confused either.
--Dave
On Mon, Jan 30, 2017 at 1:00 PM, kearney <kearney(at)shaw.ca (kearney(at)shaw.ca)> wrote:
--> RV10-List message posted by: "kearney" <kearney(at)shaw.ca (kearney(at)shaw.ca)>
Hi
Cheers
Les
http://forums.matronics.com/viewtopic.php?p=465577#465577
--Dave
KWVI
gengrumpy
PostPosted: Mon Jan 30, 2017 7:08 pm    Post subject: Static System Icing Reply with quote
Most interesting. Wonder how that got there? Condensation?? Rain???
grumpy
On Jan 30, 2017, at 7:28 PM, David Saylor <saylor.dave(at)gmail.com (saylor.dave(at)gmail.com)> wrote:
--Dave
--> RV10-List message posted by: "kearney" <kearney(at)shaw.ca (kearney(at)shaw.ca)> Hi A few days ago I was flying for a couple of hours in -7c wx (19F for those south of the 49th). Everything was uneventful until I was on a downwind to land when my static line became blocked. Fortunately my annual was only a couple of days away so I checked things out when I had everything opened up for inspection. I found a 1/4" column of water in the static line low point in the tail cone. As it was well below freezing there the line must have frozen thereabouts. A quick blast of air (from the panel end of the line) and the water was gone. I thought I'd mention this as something to watch for. Cheers Les Read this topic online here: http://forums.matronics.com/viewtopic.php?p=465577#465577 ==================================== -List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?RV10-List ==================================== FORUMS - eferrer" target="_blank">http://forums.matronics.com ==================================== WIKI - errer" target="_blank">http://wiki.matronics.com ==================================== b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/contribution ====================================
