kearney
Posted: Sat Feb 11, 2017 12:37 pm Post subject: W1002 Weldment Query |
When I built my -10, I had a very difficult time getting reasonable edge distances on the W1002 weldment when match drilled to the F1001B & F1004. For those haven't memorized the VANS plans & part numbers, these are the weldments that tie the engine mount to to the firewall / fuse.
Has anyone else had a problem with these?
Inquiring minds need to know...
Cheers
Les
Bob Turner
Joined: 03 Jan 2009 Posts: 881 Location: Castro Valley, CA
Posted: Sat Feb 11, 2017 2:52 pm Post subject: Re: W1002 Weldment Query |
If it's the engine mount you're talking about, yes, mine were way off. After consulting with Vans I pushed and pulled on the mount, by hand, as hard as I could, and then tied it with rope to hold that configuration. That allowed the very undersized pilot holes to be within, but no where near centered, when viewed thru the mount holes. I used the mount as a guide for the drill bit, and got clean, round holes when done. But not centered on the original pilot holes.
_________________ Bob Turner
RV-10 QB |
bill.peyton
Joined: 19 Sep 2010 Posts: 198 Location: St. Louis, MO
Posted: Sun Feb 12, 2017 5:29 am Post subject: Re: W1002 Weldment Query |
I too had issues with alignment. I used a rope and Polly to stretch the mount. I was able to get all holes lined up. I started with the top, which lined up without much effort for me, then the bottom two outside holes which required a lot of stretching. The hard part was inserting the bolts after having to remove the mount again.
_________________ Bill
WA0SYV
Aviation Partners, LLC |
kearney
Posted: Sun Feb 12, 2017 7:17 am Post subject: Re: W1002 Weldment Query |
Hmmm
This sounds like the problem I had. Unfortunately, when I used clamps and ropes etc there was a significant flex in the firewall due to the weldments. To me it seems like there is a design issue here.
Cheers
Les
philperry9
Posted: Sun Feb 12, 2017 8:05 am Post subject: W1002 Weldment Query |
All these problems makes me want to go back and re-check mine. I didn't have any issues.
Quote: | On Feb 12, 2017, at 9:17 AM, kearney <kearney(at)shaw.ca> wrote:
Hmmm
Cheers
Les
http://forums.matronics.com/viewtopic.php?p=466046#466046
Posted: Sun Feb 12, 2017 10:06 am Post subject: W1002 Weldment Query |
The W1002 is not the engine mount. He's talking about the part that it bolts to aft of the firewall.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
C: 352-427-0285
F: 815-377-3694
Quote: | On Feb 12, 2017, at 10:56 AM, Phillip Perry <philperry9(at)gmail.com> wrote:
> Hmmm
> Cheers
> Les
Kelly McMullen
Posted: Sun Feb 12, 2017 12:16 pm Post subject: W1002 Weldment Query |
The area being discussed was built for you in your quick build.
-sent from the I-droid implanted in my forearm
On Sun, Feb 12, 2017 at 8:56 AM, Phillip Perry <philperry9(at)gmail.com (philperry9(at)gmail.com)> wrote:
Quote: | --> RV10-List message posted by: Phillip Perry <philperry9(at)gmail.com (philperry9(at)gmail.com)>
> On Feb 12, 2017, at 9:17 AM, kearney <kearney(at)shaw.ca (kearney(at)shaw.ca)> wrote:
> --> RV10-List message posted by: "kearney" <kearney(at)shaw.ca (kearney(at)shaw.ca)>
> Hmmm
> Cheers
> Les
FORUMS -
WIKI -
b Site -
-Matt Dralle, List Admin.
A&P/IA, EAA Tech Counselor
KCHD |
