Kannad Integra ELT
art(at)zemon.name
PostPosted: Mon Feb 27, 2017 4:00 pm    Post subject: Kannad Integra ELT Reply with quote
Folks,
Do you have any thoughts about the Kannad Integrat ELT? It is several hundred dollars less expensive than the competition.
https://www.aircraftspruce.com/catalog/avpages/kannadintegraeasy.php
    -- Art Z.
https://CheerfulCurmudgeon.com/"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel
yellowduckduo(at)gmail.co
PostPosted: Mon Feb 27, 2017 5:50 pm    Post subject: Kannad Integra ELT Reply with quote
A couple of years ago my choice came down to a kannad that does not
need an external antenna but does take several minutes to locate its gps
position
or
the Ack that receives gps location from my portable nav gps and aircraft
power whenever my master switch is on, and can therefore instantly
transmit that gps position without taking minutes to locate the gps
position when activated.
The satelites should get a rough triangulated position from the kannad
immediately but not a precise gps position. OTOH loss of an external
antenna on competing ELT's is a significant concern. I don't know how
much of this still applies to the current units.
Ken
On 27/02/2017 6:55 PM, Art Zemon wrote:
Folks,
-- Art Z.
what am I? And if not now, when?" Hillel/
kenryan
PostPosted: Mon Feb 27, 2017 6:19 pm    Post subject: Kannad Integra ELT Reply with quote
I chose the Kannad because it was the smallest and the lightest. As time has passed, however, I came to desire that my ELT always have my GPS position ready to send as soon as I hit the button. So I ordered the NEMA connector for the Kannad that will allow that, but it is a very expensive part and I have been waiting for it for nearly two months now.
On Mon, Feb 27, 2017 at 4:48 PM, C&K <yellowduckduo(at)gmail.com (yellowduckduo(at)gmail.com)> wrote:
--> AeroElectric-List message posted by: C&K <yellowduckduo(at)gmail.com (yellowduckduo(at)gmail.com)>
A couple of  years ago my choice came down to a kannad that does not need an external antenna but does take several minutes to locate its gps position
or
the Ack that receives gps location from my portable nav gps and aircraft power whenever my master switch is on, and can therefore instantly transmit that gps position without taking minutes to locate the gps position when activated.
The satelites should get a rough triangulated position from the kannad immediately but not a precise gps position. OTOH loss of an external antenna on competing ELT's is a significant concern. I don't know how much of this still applies to the current units.
Ken
Folks,
    -- Art Z.
/"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel/
art(at)zemon.name
PostPosted: Mon Feb 27, 2017 7:15 pm    Post subject: Kannad Integra ELT Reply with quote
That's really good info. Thank you two. I had not realized that the Kannad did not continually know its location. Since I am building a metal airplane, I don't think the Kannad's internal antenna will be of any use at all.
    -- Art Z.
On Mon, Feb 27, 2017 at 8:16 PM, Ken Ryan <keninalaska(at)gmail.com (keninalaska(at)gmail.com)> wrote:
or
PostPosted: Mon Feb 27, 2017 8:02 pm    Post subject: Kannad Integra ELT Reply with quote
I've been told that enough signal leaks out that they work just fine in
a metal fuselage.
I don't have a kannad but In Canada we can get an email confirming
satellite reception when testing Elt's and I've never heard a complaint
about kannad reception.
I can say that the satellites pick up tests from an Ack unit in the back
of a metal T hangar just fine so I can believe the kannads function as
claimed.
Ken
any use at all.
-- Art Z.
<mailto:yellowduckduo(at)gmail.com>> wrote:
<yellowduckduo(at)gmail.com <mailto:yellowduckduo(at)gmail.com>>
or
glastar(at)gmx.net
PostPosted: Mon Feb 27, 2017 10:10 pm    Post subject: Kannad Integra ELT Reply with quote
Hello Art,
it is a fine piece of equipment and the internal antenna is a plus, but
I do not understand your price question as an example:
https://www.aircraftspruce.com/catalog/avpages/artex11-13989.php
https://www.aircraftspruce.com/pages/av/elts_zack/elt406.php
are several hundred $ cheaper or even less then half the price of the Kannad
Cheers Werner
On 28.02.2017 00:55, Art Zemon wrote:
Folks,
stuart(at)stuarthutchison
PostPosted: Tue Feb 28, 2017 2:53 am    Post subject: Kannad Integra ELT Reply with quote
Hey Ken,
There’s an important safety point to clarify.
The RCC will know that you (specifically you) are experiencing an emergency almost immediately after a serviceable 406 ELT activation, but without a GPS position they can’t know where you are because the satellites can't fix "a rough triangulated position" in quick time. To fix non-GPS ELTs, a range of multi-role Low Earth Orbit (LEO) satellites (such as NOAA satellites with a COSPAS/SARSAT payload) track a network of orbital paths over the Earth (seemingly straight-line to a ground-based observer). These satellites receive and triangulate ELT/PLB/EPIRB fixes sent on 406.025 MHz, but the satellite can’t tell which side you are on, so one satellite pass produces both a true and a false Doppler fix on opposite sides of track. Unless one fix is wildly improbable, first responders will often wait for a second, corroborating fix to resolve the ambiguity. Coverage is probably more saturated over the USA than here in Aus, but it can still take hours to resolve the ambiguity with a second LEO satellite pass on a different track. The accuracy of the Doppler fix depends on the stability of the ELT transmission frequency, which is why the old 121.5 / 243.0 MHz satellite receiver component was decommissioned over a decade ago (and that swept-tone ELT signals were generic and not unique to a particular platform, plus there was a 95% false alarm rate). For example, one of our old C-130H ELTs ejected from the tail in a known location and it took the LEO satellite system 9.5 hours to Doppler fix the initial location. Admittedly that was 121.5 / 243.0 MHz with poor frequency stability, but its the same LEO satellite network Doppler fixing our modern 406.025MHz signals. ELTs are still required to have 121.5 MHZ (and perhaps 243.0 MHz for military) as a homing signal for the final rescue itself, but this is why GPS is so important.
Once activated, most modern GPSs will fix themselves in seconds (up to less than a few minutes depending on almanac download status, which happens via the GPS satellites) and then append the fix position in the 'long message' format to the Rescue Coordination Centre (RCC) via a GEO-stationary satellite (orbiting at the same rate the Earth rotates in space, so essentially stationary overhead each continent). In this way an accurate GPS position is simply ‘bounced' off the GEO satellite to the RCC rather than waiting for passing LEO satellites to Doppler fix. Before the first GPS fix is achieved the ELT will nevertheless relay your unique 15 digit HEXID to the RCC (which, BTW, can be programmed to incorporate the 24-bit address code assigned to the aircraft’s ADS-B transponder if you have one), so the RCC knows you have an emergency almost instantly.
Food for thought:
If you turn the ELT on in flight, it will begin to GPS fix and append the position in the signal to the RCC, but it could be that first fix takes longer than you have before reaching the ground/water. If you don’t have time to turn the ELT on, it will probably activate on impact (my Kannad Compact certainly does), however, success then depends on continued integrity of the coax cable between the ELT and its antenna, which may be vulnerable to crash damage in your particular installation (perhaps lightly retained 'service loops' would be wise). Pre-loading the ELT with aircraft GPS position buys you some time to get your position off to the RCC on the way down (if you activate the ELT), but either way, the ELT isn’t much use if the aircraft sinks underwater, in which case you would want to be floating around with a separate GPS PLB attached to you.
My decision was to install an automatic ELT with in-built GPS (non aircraft integrated) that I intend to activate immediately in an emergency. If the ELT is damaged, subsequently fails or I have to swim out of the cockpit, I also have a PLB attached to myself. Militaries the world over do this too (in both ejection seat and non-ejection seat aircraft).
V/R Stu
or
Ken
> Folks,
> Thanks,
> -- Art Z.
wdaniell.longport(at)gmai
PostPosted: Tue Feb 28, 2017 3:29 am    Post subject: Kannad Integra ELT Reply with quote
Are ELT obligatory in the usa and canada?Will
On Feb 28, 2017 05:59, "Stuart Hutchison" <stuart(at)stuarthutchison.com.au (stuart(at)stuarthutchison.com.au)> wrote:
--> AeroElectric-List message posted by: Stuart Hutchison <stuart(at)stuarthutchison.com.au (stuart(at)stuarthutchison.com.au)>
Hey Ken,
The RCC will know that you (specifically you) are experiencing an emergency almost immediately after a serviceable 406 ELT activation, but without a GPS position they can’t know where you are because the satellites can't fix "a rough triangulated position" in quick time.  To fix non-GPS ELTs, a range of multi-role Low Earth Orbit (LEO) satellites (such as NOAA satellites with a COSPAS/SARSAT payload) track a network of orbital paths over the Earth (seemingly straight-line to a ground-based observer).  These satellites receive and triangulate ELT/PLB/EPIRB fixes sent on 406.025 MHz, but the satellite can’t tell which side you are on, so one satellite pass produces both a true and a false Doppler fix on opposite sides of track.  Unless one fix is wildly improbable, first responders will often wait for a second, corroborating fix to resolve the ambiguity.  Coverage is probably more saturated over the USA than here in Aus, but it can still take hours to resolve the ambiguity!
Food for thought:
V/R Stu
> On 28 Feb 2017, at 12:48, C&K <yellowduckduo(at)gmail.com (yellowduckduo(at)gmail.com)> wrote:
> or
> Ken
>> Folks,
>> Thanks,
>>    -- Art Z.
Kellym
PostPosted: Tue Feb 28, 2017 5:31 am    Post subject: Kannad Integra ELT Reply with quote
Short answer, yes.
However, in the US (I don't know Canadian specifics) even the 1st
generation, circa 1973 ELTs are legal to meet the requirement if they
were installed prior to a specified date. 2nd generation 121.5 ELTs are
required for new installations. 406 units are not required, no upgrade
requirement forecast. It is all up to the aircraft owner what they want
and are willing to pay.
One overriding consideration is that a large portion of the US fleet
must install ADS-B by 2020. It will provide an automatic trace of the
aircraft for all but the first and last few hundred feet above the
ground, depending on proximity to ground receivers. After spending $3000
and up for that equipment, owners may be reluctant to pay another $1000
for a 406 ELT and installation.
Will
Kelly McMullen
KCHD
JOHN TIPTON
PostPosted: Tue Feb 28, 2017 6:10 am    Post subject: Kannad Integra ELT Reply with quote
What are your requirements, over here (Europe) we carry these:
https://www.flightstore.co.uk/pilot-supplies-c1/safety-survival-c740/plb-and-elt-beacons-c164/mcmurdo-fastfind-220-plb-with-gps-p3878?gclid=CjwKEAiA3NTFBRDKheuO6IG43VQSJAA74F77PECVW8N0D_uBN-h8pwWywiltaxiQikL1P9fY62EjfBoC-3Hw_wcB
----x--O--x----
PostPosted: Tue Feb 28, 2017 6:23 am    Post subject: Kannad Integra ELT Reply with quote
Thanks Stu
I definitely overstated about triangulation. I concluded that the
benefit of a 406 without immediate gps position was mostly identifying
what aircraft was involved which contributes a lot. In theory if the
alert with an aircraft ID gets out with a 406, coordinating with a
flight plan etc. can quickly locate a 'very' general position which has
some value especially for relatively common landing and takeoff incidents.
Will - I'm not up to date on all the current ELT regs and
interpolations but yes ELT's are mandatory in Canada. There are still
121.5 units in service and also aircraft flying with the units removed
for annual certifications though.
Ken
Will
<stuart(at)stuarthutchison.com.au <mailto:stuart(at)stuarthutchison.com.au>>
Hey Ken,
Food for thought:
V/R Stu
> or
> Ken
>> Folks,
<https://www.aircraftspruce.com/catalog/avpages/kannadintegraeasy.php>
>> Thanks,
>> -- Art Z.
>> https://CheerfulCurmudgeon.com/ <https://CheerfulCurmudgeon.com/>
Electric-List" rel="noreferrer"
target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
alec(at)alecmyers.com
PostPosted: Tue Feb 28, 2017 6:46 am    Post subject: Kannad Integra ELT Reply with quote
Except in limited circumstances, in Canada an ELT (either 121.5MHz or 406MHz) is required, yes.
On 28Feb2017, at 6:27 AM, William Daniell <wdaniell.longport(at)gmail.com> wrote:
Will
On Feb 28, 2017 05:59, "Stuart Hutchison" <stuart(at)stuarthutchison.com.au> wrote:
Hey Ken,
Food for thought:
V/R Stu
or
Ken
> Folks,
> Thanks,
> -- Art Z.
Eric Page
PostPosted: Tue Feb 28, 2017 7:07 am    Post subject: Kannad Integra ELT Reply with quote
Correct. For the U.S., ELT requirements are detailed in FAR 91.207.
http://preview.tinyurl.com/jhl8hfm
The exception that's most commonly applicable to the Experimental aircraft community is that single seat aircraft are exempt. The wisdom of flying alone without an emergency transmitter of some kind is another question...
Eric
On Feb 28, 2017, at 5:31 AM, Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)> wrote:
Short answer, yes.
However, in the US (I don't know Canadian specifics) even the 1st generation, circa 1973 ELTs are legal to meet the requirement if they were installed prior to a specified date. 2nd generation 121.5 ELTs are required for new installations. 406 units are not required, no upgrade requirement forecast. It is all up to the aircraft owner what they want and are willing to pay.
One overriding consideration is that a large portion of the US fleet must install ADS-B by 2020. It will provide an automatic trace of the aircraft for all but the first and last few hundred feet above the ground, depending on proximity to ground receivers. After spending $3000 and up for that equipment, owners may be reluctant to pay another $1000 for a 406 ELT and installation.
Will
kenryan
PostPosted: Tue Feb 28, 2017 8:35 am    Post subject: Kannad Integra ELT Reply with quote
Stu,
I do always carry a PLB with me.
Why don't you buy the NEMA adapter so that your Kannad always knows your GPS position. That way, when you hit that button while going down, SAR will know exactly where you are. I don't particularly like spending another $342 but it's worth it to me. Alaska is big and it's hard to find lost airplanes. Many are never found.
Ken
On Tue, Feb 28, 2017 at 1:50 AM, Stuart Hutchison <stuart(at)stuarthutchison.com.au (stuart(at)stuarthutchison.com.au)> wrote:
Hey Ken,
Food for thought:
V/R Stu
> or
> Ken
>> Folks,
>> Thanks,
>>    -- Art Z.
PostPosted: Wed Mar 01, 2017 10:27 am    Post subject: Kannad Integra ELT Reply with quote
Excellent thanks
I am planning a move from Colombia to the US hence my interest.  ELT are not required for Colombia Class 2 ultralights under which my Europa will be "certified".  So I g
William Daniell
LONGPORT
+57 310 295 0744
On Tue, Feb 28, 2017 at 9:42 AM, Alec Myers <alec(at)alecmyers.com (alec(at)alecmyers.com)> wrote:
--> AeroElectric-List message posted by: Alec Myers <alec(at)alecmyers.com (alec(at)alecmyers.com)>
On 28Feb2017, at 6:27 AM, William Daniell <wdaniell.longport(at)gmail.com (wdaniell.longport(at)gmail.com)> wrote:
Will
Hey Ken,
Food for thought:
V/R Stu
> or
> Ken
>> Folks,
>> Thanks,
>>    -- Art Z.
