Overhaul - New
Jim Combs
PostPosted: Fri Mar 17, 2017 5:56 am    Post subject: Overhaul - New Reply with quote
Questions for the group:
I am getting close to the 2000 hour point on my IO-540-C4B5 and am looking at options:
(1) Replace with a new Lycoming from Vans (47K)
(2) Replace with a Titan X540 engine from ECI (44K)
(3) Purchase an overhauled engine from ???
(4) Overhaul it myself.  I have replaced cylinders and overhauled automotive engines but not a Lycoming.
Any comments on any specific option?
Thanks, Jim Combs
N312F - Flying 1000+ Hours over a 6 year period
RV-10 -> N312F - Flying as of 12/2008
gengrumpy
PostPosted: Fri Mar 17, 2017 6:00 am    Post subject: Overhaul - New Reply with quote
Jim,
I hope that you follow Mike Busch on engine care and maintenance.
The 2000 point is n/a if you do the things that he recommends, and do the overhaul based “on condition”.
Google him up and read his articles on TBO overhauls, care and routine maintenance.
grumpy
Thanks, Jim Combs
Kelly McMullen
PostPosted: Fri Mar 17, 2017 6:48 am    Post subject: Overhaul - New Reply with quote
Depends on the availability of quality overhaulers within reasonable distance.
Sure, you can do it yourself. There are a lot of pitfalls. Lycoming doesn't make all the information available in one place.
While they have done a little updating to the overhaul manual, there are still 1000+ service bulletins that you have to see if they apply.
There have been a lot of parts changes over the years to extend TBO, etc.
I've done a few engines, partly due to economic reasons at the time.
If you supply the core engine, you should be able to get a quality overhaul for well under $40K.
You can also look at Van Bortel and a couple others that offer exchange engines for a claimed $300 over invoice.
http://www.airpowerinc.com/productcart/pc/engines.asp?searchParm=IO-540-D4A5&catID=33
That gets you a factory overhauled engine for $37K
-sent from the I-droid implanted in my forearm
On Fri, Mar 17, 2017 at 6:55 AM, Jim Combs <jiminlexky(at)gmail.com (jiminlexky(at)gmail.com)> wrote:
Thanks, Jim Combs
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
kboatright1(at)comcast.ne
Faced with needing an IO540, I went with BPE. Too many souls on board for me to do the rebuild (like I did on the engine for my RV-6). With a good core, your rebuild price should be in the low '30's. You could do it for <$20k if you did it yourself.
Another option would be to do the legwork yourself and have a shop or experienced A&P help with the assembly process.
Some of the dilemma goes back to "How good do you think your core is" and "How much do you think Lycoming's price reductions will reduce rebuild costs?".
Thanks, Jim Combs
rv10flyer(at)live.com
PostPosted: Fri Mar 17, 2017 7:03 am    Post subject: Overhaul - New Reply with quote
If it was me
(5) fly the engine until it needs to be overhauled than (4)
Mike Busch is a big advocate that engines can go into 3000+ hours without an issue. If flown often- as you have done
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jim Combs
Sent: Friday, March 17, 2017 6:56 AM
Subject: RV10-List: Overhaul - New
Thanks, Jim Combs
Jim Combs
PostPosted: Fri Mar 17, 2017 9:19 am    Post subject: Overhaul - New Reply with quote
Ok so stupid question:  What makes the engine need to be overhauled?  I do 50 hour oil changes with oil analysis on each change.  Is it a change in oil analysis showing some sort of abnormal wear and / or cylinder issues?
Never been down this road before.
Jim C
On Fri, Mar 17, 2017 at 11:03 AM, P Reid <rv10flyer(at)live.com (rv10flyer(at)live.com)> wrote:
If it was me
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Jim Combs
Subject: Overhaul - New
Thanks, Jim Combs
PostPosted: Fri Mar 17, 2017 12:07 pm    Post subject: Overhaul - New Reply with quote
As EAA members we have various webinars, one happens to be exactly what you are asking 😉
http://www.eaavideo.org/video.aspx?v=1429764450001
Pascal
Sent: Friday, March 17, 2017 10:34 AM
Subject: Re: RV10-List: Overhaul - New
Jim C
If it was me
Thanks, Jim Combs
Bob Turner
PostPosted: Fri Mar 17, 2017 1:42 pm    Post subject: Re: Overhaul - New Reply with quote
It really is a judgement call. Sometimes compressions will get poor, sometimes oil consumption will go up. Fortunately it is rare to have a catastrophic failure, but the odds probably increase a bit as you go further and further past TBO.
Bob Turner
RV-10 QB
stein(at)steinair.com
PostPosted: Fri Mar 17, 2017 2:15 pm    Post subject: Overhaul - New Reply with quote
Usually it's exactly what Bob mentions below. Many of the 'other' parts are
just IRAN (Inspect/Repair/as necessary) during an overhaul anyway. Usually
the crank/cam/case/accessory gears, etc.. all get re-used themselves. Same
with pushrods, conrods, tappets, plungers, etc..
Engines that are often flown frequently outlast engines that sit (especially
on the top end).
Cheers,
Stein
Mauledriver(at)nc.rr.com
PostPosted: Fri Mar 17, 2017 4:40 pm    Post subject: Overhaul - New Reply with quote
I've never been down that road either but I intend to follow Busch's
advice and consider 2000 hours just a milestone.
Given that you've flown regularly and probably put most/all the hours on
it personally, you would seem to be a prime candidate for taking an
on-condition approach.
Re a DIY overhaul: I attended Lycoming engine school, both classes,
which include an disassembly/assembly hands-on lab . On one hand, I
know I could do a decent job given patience and time. On the other I've
gained great respect for those individuals that DIY. It's no where near
the size and scope of kit building but there's less room for mistakes
and carelessness. The Lycoming class gave me the confidence for self
maintenance and management. If I were to do a DIY, the class would be a
prerequisite but I'm not going down that path. I recommend that class
for owner/self maintainers and DIY wannabes.
Whoever said, "the information required for a Lycoming overhaul is not
all in one place" knows their stuff, amen.
Bill "I'm planning on getting well past 2,000 hours BO" Watson
On 3/17/2017 10:00 AM, John Miller wrote:
Jim,
grumpy
flying-nut(at)cfl.rr.com
PostPosted: Fri Mar 17, 2017 5:11 pm    Post subject: Overhaul - New Reply with quote
Lycomings are dirt simple. With the assembly and parts manual I'd overhaul it myself .... the hardest thing is splitting the case.
However, I wouldn't touch it just because it has 2000 hours on it. If the engine has good oil pressure and compression .... fly it.The best thing you can do for your engine is use it often.
IMHO!
LINN
Sent from Samsung tablet cruising on the majesty Of The Seas.
From Jim Combs <jiminlexky(at)gmail.com>
Date: 03/17/2017 9:55 AM (GMT-05:00)
To rv10-list(at)matronics.com
Subject RV10-List: Overhaul - New
Thanks, Jim Combs
jerry_stark(at)prodigy.ne
PostPosted: Sat Mar 18, 2017 8:58 pm    Post subject: Overhaul - New Reply with quote
FYI:
If you really need to rebuild it I would consider talking with Barret In Tulsa. Not that much higher cost but they do a better balance, in my opinion, check with them. Also they do work for a few aerobatic pilots. People notice that my engine runs very smoothly at low rpm. Very satisfied!
A lot depends on you, when you think "you" need to do the rebuild.
Sent: Friday, March 17, 2017 8:18 PM
Subject: RE: Overhaul - New
IMHO!
LINN
Sent from Samsung tablet cruising on the majesty Of The Seas.-------- Original message --------From Jim Combs <jiminlexky(at)gmail.com> Date: 03/17/2017 9:55 AM (GMT-05:00) To rv10-list(at)matronics.com Subject Overhaul - New Questions for the group:
Thanks, Jim Combs
jdriggs49(at)MSN.COM
PostPosted: Sun Mar 19, 2017 10:38 am    Post subject: Overhaul - New Reply with quote
I have a Barrett IO-540. If you already have an engine it's a lot cheaper to rebuild as I've discussed that several times with Rhonda. I'm sold on their engines. They are very smooth and sound different than any others.
On Mar 19, 2017, at 12:02 AM, Jerry Stark <jerry_stark(at)prodigy.net (jerry_stark(at)prodigy.net)> wrote:
FYI:
From: Linn Walters <flying-nut(at)cfl.rr.com (flying-nut(at)cfl.rr.com)>
Subject: RE: RV10-List: Overhaul - New
IMHO!
LINN
Sent from Samsung tablet cruising on the majesty Of The Seas. -------- Original message -------- From Jim Combs <jiminlexky(at)gmail.com (jiminlexky(at)gmail.com)> Date: 03/17/2017 9:55 AM (GMT-05:00) To rv10-list(at)matronics.com (rv10-list(at)matronics.com) Subject RV10-List: Overhaul - New Questions for the group:
Thanks, Jim Combs
Kelly McMullen
PostPosted: Sun Mar 19, 2017 4:02 pm    Post subject: Overhaul - New Reply with quote
No question BPA does superb overhauls. There are a dozen or so top notch rebuilders around the country. Mine was produced by Lycon Engines in Visalia, CA. I get comments from almost all pilots who hear it taxi by or idle at how smooth it sounds. I suggest that quality shops that are within say 3 hours flying distance are a bit easier to work with, because of proximity, they are probably familiar with your climate and elevation and can tune to that. Not to mention that if the unusual problem crops up, it is easier for all to get the builder and the engine back together to resolve the issue.
I will also suggest that a shop that does nothing but engines is going to do a better job that is more likely to reach TBO than one you do yourself. You will get some warranty, something you can't provide to yourself. I have the knowledge, license and experience to do an overhaul, but if I have the time and money, I would rather one of the expert shops do the job.
On Sun, Mar 19, 2017 at 11:36 AM, Danny Riggs <jdriggs49(at)msn.com (jdriggs49(at)msn.com)> wrote:
Kelly McMullen
KCHD
jesse(at)saintaviation.co
PostPosted: Sun Mar 19, 2017 7:47 pm    Post subject: Overhaul - New Reply with quote
Amen to all of this.
Jesse Saint
Saint Aviation, Inc.
352-427-0285
Sent from my iPad
On Mar 19, 2017, at 8:00 PM, Kelly McMullen <apilot2(at)gmail.com (apilot2(at)gmail.com)> wrote:
