Aerosport Side Vents - Rear Interior Panel
philperry9
PostPosted: Thu Mar 23, 2017 5:43 am    Post subject: Aerosport Side Vents - Rear Interior Panel Reply with quote
I've spent the better part of 6 hours trying to fit one side vent on my interior panels so I can complete my W&B.
In the process I've invented cuss words that even a sailor at sea would be ashamed of saying if there were a shipmate standing near.
The problem is the duct that goes between the Vans inlet that ducts the air to the interior panel vent cover.  First, it doesn't sit flat against the backside of the skin because of the rivets and doubler holding Vans vent.   So every attempt to seat it is different from the previous attempt.  And second, the duct repeatedly falls off the backside of the interior panel every time I try to work it into position.
I have to be the problem because I haven't heard any complaints from other folks getting these things to fit.
I've notched the duct as described in the installation documents, so I don't believe that is the problem.
Has anyone found a technique, tip, or even modification to make this as simple as it appears it should be?
Phil
john(at)trollingers.com
PostPosted: Thu Mar 23, 2017 6:14 am    Post subject: Aerosport Side Vents - Rear Interior Panel Reply with quote
I had the same issues you did.. I had to cut down the duct to get it to fit at all.. I do not remember if I just threw away the vents or finally got it to work..
On Thu, Mar 23, 2017 at 9:40 AM, Phillip Perry <philperry9(at)gmail.com (philperry9(at)gmail.com)> wrote:
Phil
flysrv10(at)gmail.com
PostPosted: Fri Mar 24, 2017 1:38 am    Post subject: Aerosport Side Vents - Rear Interior Panel Reply with quote
Me. too. I did the best I could with them.
The panels seem to act as a big plenum adn you will still get the ventilation but the ducts sure don't fit.
do not archive.
On Mar 23, 2017, at 10:14 AM, John Trollinger <john(at)trollingers.com (john(at)trollingers.com)> wrote:
Phil
vernon.franklin(at)gmail.
PostPosted: Fri Mar 24, 2017 4:00 am    Post subject: Aerosport Side Vents - Rear Interior Panel Reply with quote
I just did my side vent installation back in February.  The vent installed pretty easily, no real issues.  The rivets went around the vent itself, didn't interfere with the placementHere are some pictures I took of the vent and bar installation.  Hope it helps.
Vernon
On Thu, Mar 23, 2017 at 8:40 AM, Phillip Perry <philperry9(at)gmail.com (philperry9(at)gmail.com)> wrote:
Phil
Vernon Franklin
