Yak-List Digest: 4 Msgs - 04/02/17
BKENNAMORE(at)aol.com
PostPosted: Mon Apr 03, 2017 8:04 am    Post subject: Yak-List Digest: 4 Msgs - 04/02/17 Reply with quote
check main acc.shaft
In a message dated 4/3/2017 2:16:15 A.M. Central Daylight Time, yak-list(at)matronics.com writes:
"woodja51" <mwuillemin(at)mac.com>
Viperdoc
PostPosted: Tue Apr 04, 2017 1:12 pm    Post subject: Yak-List Digest: 4 Msgs - 04/02/17 Reply with quote
None to minimal compression with pulling the prop was stated in the message along with normal pressures/ gauges? Or did I miss something. Bad vibration nothing said about wind milling prop.
Sheared prop shaft in the nose case? But would have a windmilling prop. Definitely has metal in the cylinders.
Tear down in order to figure this out.
Doc
Sent from my iPad
On Apr 3, 2017, at 11:01 AM, BKENNAMORE(at)aol.com (BKENNAMORE(at)aol.com) wrote:
In a message dated 4/3/2017 2:16:15 A.M. Central Daylight Time, yak-list(at)matronics.com (yak-list(at)matronics.com) writes:
"woodja51" <mwuillemin(at)mac.com (mwuillemin(at)mac.com)>
Viperdoc
