dlm34077(at)gmail.com Guest
Posted: Wed May 03, 2017 5:58 pm Post subject: cowl heat |
just recently discovered (1200TT) that the lower cowl has three areas of delaminated
fiberglass. Preparing for the repair I found a thin honeycomb and reportedly 5 layers of glass.
 The areas of delamination seemed to be directly below the three in one connection to the heat muff and the exhaust tube of #6. Has anyone else experienced this problem? possibly the higher temperatures of the Southwestern USA are to blame. I have been opening the oil door after each landing to keep the under cowl temperatures under control.Â
Posted: Wed May 03, 2017 6:13 pm Post subject: cowl heat |
I have seen this on a number of planes that do not have heat shield in those areas. The inside of the cowl turns brown, then black, then starts to delaminate on the inside, then starts to delaminate on the outside. I have seen all stages of this. Remove the delaminates part, lay up new glass to cover that area with an overlap of the surrounding areas, then add heat shield after it cures.
Jesse Saint
Saint Aviation, Inc.
352-427-0285
jesse(at)saintaviation.com
sportav8r(at)gmail.com Guest
Posted: Thu May 04, 2017 5:35 am Post subject: cowl heat |
Jesse, should this be stick-on reflective foil or does it need some backing layer or a stand-off air gap to be effective?
-Bill
On Wed, May 3, 2017 at 10:13 PM, Jesse Saint <jesse(at)saintaviation.com (jesse(at)saintaviation.com)> wrote:
Quote: | --> RV10-List message posted by: Jesse Saint <jesse(at)saintaviation.com (jesse(at)saintaviation.com)>
Jesse Saint
[url=tel:352-427-0285]352-427-0285[/url]
> On May 3, 2017, at 9:57 PM, dlm <dlm34077(at)gmail.com (dlm34077(at)gmail.com)> wrote:
>Â The areas of delamination seemed to be directly below the three in one connection to the heat muff and the exhaust tube of #6. Has anyone else experienced this problem? possibly the higher temperatures of the Southwestern USA are to blame. I have been opening the oil door after each landing to keep the under cowl temperatures under control.
Posted: Thu May 04, 2017 8:23 am Post subject: cowl heat |
I experienced the burn problem. Once repaired, I used Thermo-Guard FR Â
There is a reflective layer and some kind of insulating padding (air gap). There have been no signs of further damage several hundred hours later.
In my unqualified opinion, I beleive that a reflective only shield would work fine. But I have no experience to bear that out.
On 5/4/2017 9:34 AM, Bill Boyd wrote:
Quote: | Jesse, should this be stick-on reflective foil or does it need some backing layer or a stand-off air gap to be effective?
-Bill
Jesse Saint
Posted: Thu May 04, 2017 8:43 am Post subject: cowl heat |
The stick-on reflective foil is sufficient to prevent the delamination. Other types of material may protect the fiberglass better, but I can’t speak to that. Jesse SaintSaint Aviation, Inc.jesse(at)saintaviation.com (jesse(at)saintaviation.com)C: 352-427-0285F: 815-377-3694
Quote: | On May 4, 2017, at 9:34 AM, Bill Boyd <sportav8r(at)gmail.com (sportav8r(at)gmail.com)> wrote:
-Bill
On Wed, May 3, 2017 at 10:13 PM, Jesse Saint <jesse(at)saintaviation.com (jesse(at)saintaviation.com)> wrote: Quote: | --> RV10-List message posted by: Jesse Saint <jesse(at)saintaviation.com (jesse(at)saintaviation.com)>I have seen this on a number of planes that do not have heat shield in those areas. The inside of the cowl turns brown, then black, then starts to delaminate on the inside, then starts to delaminate on the outside. I have seen all stages of this. Remove the delaminates part, lay up new glass to cover that area with an overlap of the surrounding areas, then add heat shield after it cures.Jesse SaintSaint Aviation, Inc.jesse(at)saintaviation.com (jesse(at)saintaviation.com)Sent from my iPad> On May 3, 2017, at 9:57 PM, dlm <dlm34077(at)gmail.com (dlm34077(at)gmail.com)> wrote:>> just recently discovered (1200TT) that the lower cowl has three areas of delaminated> fiberglass. Preparing for the repair I found a thin honeycomb and reportedly 5 layers of glass.> The areas of delamination seemed to be directly below the three in one connection to the heat muff and the exhaust tube of #6. Has anyone else experienced this problem? possibly the higher temperatures of the Southwestern USA are to blame. I have been opening the oil door after each landing to keep the under cowl temperatures under control.>====================================-List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?RV10-List====================================FORUMS -eferrer" target="_blank">http://forums.matronics.com====================================WIKI -errer" target="_blank">http://wiki.matronics.com====================================b Site - -Matt Dralle, List Admin.rel="noreferrer" target="_blank">http://www.matronics.com/contribution==================================== |
Tim Olson
Posted: Thu May 04, 2017 9:13 am Post subject: cowl heat |
I've had no issues with just reflective stick-on foil.
If you can do that all over and add a patch with the
insulated backing near the very closest areas, you would
maybe even be better off, but I have no complaints
with what I have.
On 5/4/2017 11:23 AM, Bill Watson wrote:
Quote: | I experienced the burn problem. Once repaired, I used Thermo-Guard FR
<https://www.aircraftspruce.com/catalog/eppages/thermoguard.php?clickkey=25931>
later.
> -Bill
rnewman(at)tcwtech.com Guest
Posted: Thu May 04, 2017 9:19 am Post subject: cowl heat |
I have the adhesive backed aluminum foil on the lower cowl. 400 hrs and no trouble with delamination or any other heat related defects. It was easy and effective.
Bob NewmanTCW Technologies, LLC
610-928-3420
On May 4, 2017, at 12:40 PM, Jesse Saint <jesse(at)saintaviation.com (jesse(at)saintaviation.com)> wrote:
Quote: | The stick-on reflective foil is sufficient to prevent the delamination. Other types of material may protect the fiberglass better, but I can’t speak to that. Jesse SaintSaint Aviation, Inc.jesse(at)saintaviation.com (jesse(at)saintaviation.com)C: 352-427-0285F: 815-377-3694
-Bill
wgreenley
Joined: 09 Jan 2010 Posts: 100 Location: Dowagiac, MI
Posted: Thu May 04, 2017 9:29 am Post subject: cowl heat |
How did you finish the interior of your cowl before applying foil?
On Thu, May 4, 2017 at 1:19 PM, Tcwtech <rnewman(at)tcwtech.com (rnewman(at)tcwtech.com)> wrote:
Quote: | I have the adhesive backed aluminum foil on the lower cowl.  400 hrs and no trouble with delamination  or any other heat related defects.  It was easy and effective.Â
[url=tel:(610)%20928-3420]610-928-3420[/url]
Jesse Saint
C: [url=tel:(352)%20427-0285]352-427-0285[/url]
F: [url=tel:(815)%20377-3694]815-377-3694[/url]
-Bill
Jesse Saint
Quote: | On May 3, 2017, at 9:57 PM, dlm <dlm34077(at)gmail.com (dlm34077(at)gmail.com)> wrote:
rene(at)felker.com Guest
Posted: Thu May 04, 2017 9:32 am Post subject: cowl heat |
Same here. >650 hrs.
Rene'
801-721-6080
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tcwtech
Sent: Thursday, May 04, 2017 11:19 AM
Subject: Re: cowl heat
Bob Newman
610-928-3420
Jesse Saint
C: 352-427-0285
F: 815-377-3694
-Bill
Jesse Saint
Posted: Thu May 04, 2017 9:42 am Post subject: cowl heat |
Several coats of thinned epoxy. Degreaser at the end.
Rene'
801-721-6080
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of William Greenley
Sent: Thursday, May 04, 2017 11:29 AM
On Thu, May 4, 2017 at 1:19 PM, Tcwtech <rnewman(at)tcwtech.com (rnewman(at)tcwtech.com)> wrote: Quote: |
Bob Newman
Jesse Saint
-Bill
Jesse Saint
Posted: Thu May 04, 2017 10:15 am Post subject: cowl heat |
A coat of thinned epoxy and then I actually just had my painter shoot a coat of white inside the whole cowl. That way any area that didn’t get foil would still look nice and clean up easily. Works as anticipated.
-Bob
Sent: Thursday, May 04, 2017 1:28 PM
Bob Newman TCW Technologies, LLC
Jesse Saint
-Bill
Jesse Saint
