Automatic header tank filling
air.peter(at)googlemail.c
PostPosted: Tue May 30, 2017 2:43 am    Post subject: Automatic header tank filling Reply with quote
Hi,
I am flying a Lancair 360 with wing tanks and the standard header tank. Rather thinking every 20 to 30 minutes to fill up the header tank again I would like to have an automatism filling the tank.
I have a capacitive fuel gauge (output 0 to 5 V) and an independent emergency reminder looking up at the annunciator panel (at) about 5 gallons.
Rather re-inventing the wheel – is there a circuit diagram out there I can use for such a fuel filling mimic ?
Thanks in advance,
Peter
LNC 360 MKII
D-EPSO
PostPosted: Tue May 30, 2017 10:05 am    Post subject: Automatic header tank filling Reply with quote
Hi,
I've done a couple of similar systems. Last
one was for the Piaggio P-180.
The analog output makes the 'control' easy to do.
The dragon to slay is failure mitigation.
Any time you add a automatic feature to the
airplane, it's wise to assume that it will
fail at some point.
What are the ways it can fail? How will you
become aware of the failure? Is the failure
pre-flight detectable? What are plans A, B, etc.
for dealing with the failure(s)?
You have a low level warning light . . . this should
be totally independent of any other function.
Suppose the transfer sticks ON and overfills the
tank. What happens if the tank is over filled;
what happens to excess fuel? Is there a practical
way to add a high level warning?
You can watch the dc voltage from the
fuel gage with a comparator that will,
for example, turn the transfer ON at
3 volts or below and OFF at 4 volts or
above . . . or what ever hysteresis values
seem most practical.
The existing low level warning backs up
a failure to transfer, some kind of high
level warning should back of a failure to
stop transferring.
ceengland7(at)gmail.com
PostPosted: Wed May 31, 2017 4:45 am    Post subject: Automatic header tank filling Reply with quote
On Tue, May 30, 2017 at 1:03 PM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
Hi,
  fail at some point.
  stop transferring.
"Suppose the transfer sticks ON and overfills the
  tank. What happens if the tank is over filled;   what happens to excess fuel? Is there a practical  way to add a high level warning?"
The additional issue I never considered (but a research scientist friend who tests *everything*, did), was what happens to the *tank*. If you have a typical vent system using -4 (1/4" OD) tubing, when fuel hits the vent, the transfer pump can cause pressures in the tank to reach 10 psi. In case you don't know, more than about 2 psi will damage most a/c fuel tanks in planes like most of us fly.
Dilemma: positive protection from overfilling that can't fail and prevent transfer.
Secondary dilemma, when using auto-transfer: Especially if there's more than one aux tank, preventing the transfer pump from running (and destroying itself) when pumping from an empty tank.
