SL-70 Install /Configuration issues -> Installation Manual
recapen(at)earthlink.net
PostPosted: Wed Jun 07, 2017 5:13 am    Post subject: SL-70 Install /Configuration issues -> Installation Manual Reply with quote
Working on an installation/configuration issue related to my SL-70.
The latest Installation Manual I have is dated October 1999 and does not reference how to enable the EXTended mode or that it is available. It is available in the software in my SL-70 and I have been provided instructions to successfully enable the EXTended mode - but I would like to know if there are any other differences outlined in a later manual. Software currently in the SL-70 is MICR 015 and FPGA 1.1 from the set-up screen and offers the EXTended mode option in the configuration. Does anyone out there have a later version of the SL-70 Installation Manual?
I want to make sure it is working properly while helping my ADSB equipment vendor! The SL-70 Installation Manual references the Altitude message only. I have the SL-70R manual dated September 2003 and there are enough
differences that I am confident it does NOT fully apply to the SL-70! The SL-70R Installation Manual references the EXTended mode and "Mode" messages that are transmitted when the EXTended mode is enabled...hopefully, this info is also present in a later version of the SL-70 Installation Manual.
Does anyone out there know how to 'capture' the RS-232 data as it is transmitted from the SL-70 in a readable format? I have a serial port on my computer connected to the TX pin from the SL-70 and set to 1200, 8, 1, N in HYPERTERM (old Windows software). It does capture the 'bursts' of data but the results are unintelligible on the software screen. The SL-70 Install Manual gives me a good idea about what I 'should' be seeing. Maybe I need special settings or special software!
Any help or suggestions greatly appreciated!
Ralph Capen
