Can Westach Use 5VDC?
billhuntersemail(at)gmail
PostPosted: Wed May 31, 2017 3:34 pm    Post subject: Can Westach Use 5VDC? Reply with quote
I have two Westack capacitance fuel probes and I would like to power them from PIN 18 of the Dynon Skyview. That pin is a 5 VDC output and the only other item that this pin will power is a Grand Rapids CS-02 Hall Effect Sensor.
Any experience would be most appreciated!!!
Cheers!!!
Bill Hunter
matronics(at)rtist.nl
PostPosted: Wed May 31, 2017 10:13 pm    Post subject: Can Westach Use 5VDC? Reply with quote
From the specifications it doesn't appear you can use 5V to power these probes. They are specified 12/24V (28V max), with the output being 0-5V. You should power them from the main bus, or (if your Skyview installation manual lists it), to the +12V Auxiliary Output pin (pin 15 of the 37-pin connector). Not all SkyView systems appear to have that pin so double check.
On 6/1/2017 1:33 AM, William Hunter wrote:
<![endif]--> <![endif]-->
Cheers!!!
Bill  Hunter
PostPosted: Wed Jun 07, 2017 9:28 am    Post subject: Can Westach Use 5VDC? Reply with quote
Rob,
It took awhile for me to get back to this thread but THANKS!!!
For posterity sake, I tried the 5 VDC power source from Skyview and that did not work however the 12 VDC PIN 15 works great!!!
Now I can check fuel by just firing up the Skyview (press and hold button #1) and do not need to have to connect the battery master!!!
Bill Hunter On Jun 1, 2017 2:19 AM, "Rob Turk" <matronics(at)rtist.nl (matronics(at)rtist.nl)> wrote:
Cheers!!!
Bill  Hunter
