SL-70 Install /Configuration issues -> Installation Manual
dan(at)syz.com
PostPosted: Wed Jun 07, 2017 11:58 am    Post subject: SL-70 Install /Configuration issues -> Installation Manual Reply with quote
First of all, I have to say I don't know anything about the SL-70. But I thought I'd just mention one possibility - if you see bursts of unintelligible data, that's often indicative of a non-matching baud rate. Do you know for sure that the SL-70 transmits its data at 1200 bps? That's actually a fairly slow rate... again, without knowing the specs of the SL-70, I'd expect higher - like maybe around 9600. If you're not sure of the baud rate, try higher rates and see if you find one that gives intelligible data.
Dan
Does anyone out there know how to 'capture' the RS-232 data as it is transmitted from the SL-70 in a readable format? I have a serial port on my computer connected to the TX pin from the SL-70 and set to 1200, 8, 1, N in HYPERTERM (old Windows software). It does capture the 'bursts' of data but the results are unintelligible on the software screen. The SL-70 Install Manual gives me a good idea about what I 'should' be seeing. Maybe I need special settings or special software!
Any help or suggestions greatly appreciated!
Ralph Capen
Dan Charrois
President, Syzygy Research & Technology
Phone: 780-961-2213
