Antsplat products
flysrv10(at)gmail.com
PostPosted: Sun Jun 18, 2017 10:35 pm    Post subject: Antsplat products Reply with quote
Hello All,
Anyone using oil separator made by Antisplat Aero?
Thanks.
Rob Kermanj
jesse(at)saintaviation.co
PostPosted: Mon Jun 19, 2017 3:45 am    Post subject: Antsplat products Reply with quote
I know quit a few people are, but there have been problems with the port that dumps the air into the exhaust clogging and blowing out the front crankshaft seal. Unless that problem has been addressed, don't use that part of the system.
Jesse Saint
Saint Aviation, Inc.
352-427-0285
Sent from my iPad
On Jun 18, 2017, at 5:13 PM, Rob Kermanj <flysrv10(at)gmail.com (flysrv10(at)gmail.com)> wrote:
Hello All,
Thanks.
Rob Kermanj
Kelly McMullen
PostPosted: Mon Jun 19, 2017 5:03 am    Post subject: Antsplat products Reply with quote
IIRC there has been a discussion or two on oil/air separators that folks have been happy with. Seems like Super Slime fighter might have been one.
-sent from the I-droid implanted in my forearm
On Mon, Jun 19, 2017 at 4:43 AM, Jesse Saint <jesse(at)saintaviation.com (jesse(at)saintaviation.com)> wrote:
Jesse Saint
[url=tel:(352)%20427-0285]352-427-0285[/url]
Sent from my iPad
Hello All,
Thanks.
Rob Kermanj
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
PostPosted: Mon Jun 19, 2017 8:19 am    Post subject: Antsplat products Reply with quote
Had a similar issue with my Andair separator. A press fit baffle came loose and blocked the exit line causing a lot of engine oil leaks. A cutter pin holding the baffle fixed the problem.
On Jun 19, 2017, at 7:43 AM, Jesse Saint <jesse(at)saintaviation.com (jesse(at)saintaviation.com)> wrote:
I know quit a few people are, but there have been problems with the port that dumps the air into the exhaust clogging and blowing out the front crankshaft seal. Unless that problem has been addressed, don't use that part of the system. Jesse Saint
352-427-0285
Sent from my iPad
Hello All,
Thanks.
Rob Kermanj
flying-nut(at)cfl.rr.com
PostPosted: Mon Jun 19, 2017 8:34 am    Post subject: Antsplat products Reply with quote
I'm not a fan of air/oil separators.  If you have too much oil on the belly from the crankcase breather then there is a problem lurking in your engine.  The air/oil separators are a bandaid that covers up the results of excessive blow-by from broken or worn-out rings.  As has been posted already, failure of the separator can be terribly expensive.
A better (in my mind) solution to an oily belly would be to extend the breather tube down lower in the slipstream. IMHO.
Linn
352-427-0285
Sent from my iPad
Hello All,
Thanks.
Rob Kermanj
Checked by AVG - www.avg.com
Date: 06/19/17
tomrv4
PostPosted: Mon Jun 19, 2017 8:49 am    Post subject: Antsplat products Reply with quote
Is there a reason why a well vented container to catch the blow by mounted low on the firewall could not be used?
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Linn Walters
Sent: Monday, June 19, 2017 11:34 AM
Subject: Re: Antsplat products
Linn
Jesse Saint
352-427-0285
Sent from my iPad
Hello All,
Thanks.
Rob Kermanj
Date: 06/19/17
Tom
San Antonio
PostPosted: Mon Jun 19, 2017 9:31 am    Post subject: Antsplat products Reply with quote
None at all.  Use a tall glass jar ..... like olives come in .....  and put a stainless scrubby (or two) in the bottom around the tube.  Depending on the amount of blow-by you may get some mist of oil near the jar.   Check the oil level in the jar during your preflight if you can see it through the air exit ramp.
Linn
On 6/19/2017 12:49 PM, Tom Chapman wrote:
<![endif]--> <![endif]-->
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Linn Walters
Linn
Jesse Saint
352-427-0285
Sent from my iPad
Hello All,
Thanks.
Rob Kermanj
Date: 06/19/17
Date: 06/19/17
Kelly McMullen
PostPosted: Mon Jun 19, 2017 11:34 am    Post subject: Antsplat products Reply with quote
Not necessarily true. There is an art to finding where to terminate the breather tube so that it is in neither high nor low pressure area. If in low pressure area, extra blowby departs the crankcase. I have seen brand new engines, built with rings in spec, that had too much oil out the breather tube. It most certainly was NOT an mechanical problem. IMHO, breathers with or without separators should not be connected to the exhaust system. The relative pressure also determines how much oil you can keep in the sump. A well designed separator should have nothing that can come loose into the airstream. How you deal with the separated oil is a whole 'nuther debate.
On Mon, Jun 19, 2017 at 9:33 AM, Linn Walters <flying-nut(at)cfl.rr.com (flying-nut(at)cfl.rr.com)> wrote:
Kelly McMullen
KCHD
PostPosted: Mon Jun 19, 2017 12:11 pm    Post subject: Antsplat products Reply with quote
I'm sure there are installations that are problematic, but I've not come across one personally.  Most of the crankcase vents I've dealt with are in the nose of the crankcase and the routing of the hose back to the firewall typically drop a little as the hose makes it's way aft which means that a little oil in the tube always drains aft .... and drips on the hangar floor.  As you said .... even engines in great shape may drip.
This will be my second encounter using the accessory case for the vent .... my O-360 in my Pitts was the first .... but the inverted oil system routes all the excess back to the tail.
Speaking of which, the Grummans have a 'whistle hole' on the tube up inside the cowl to prevent freezing over the tube and blocking the vent.  I don't think that's a common practice on the Vans vents for whatever reason.
Linn
Date: 06/19/17
Kelly McMullen
PostPosted: Mon Jun 19, 2017 1:07 pm    Post subject: Antsplat products Reply with quote
Only Continental engines have the vent on the nose of the case, AFAiK. Lycomings use the accessory case, and they like to blow overboard oil that is above a certain amount. It is easier with the Continentals to have an uphill run of some distance to condense the oil back out of the blowby stream. My planes with Lycoming engines typically did not drip from the vent after shut down. But they did ensure that the belly had a fine mist of oil. If it weren't a common problem, there would not be so many "solutions" on the market.
On Mon, Jun 19, 2017 at 1:11 PM, Linn Walters <flying-nut(at)cfl.rr.com (flying-nut(at)cfl.rr.com)> wrote:
Linn
Date: 06/19/17
Kelly McMullen
KCHD
