Tire / Brake Life
kearney
PostPosted: Fri Jul 07, 2017 5:31 pm    Post subject: Tire / Brake Life Reply with quote
Hi
I was checking my tire pressure today and started thinking about when I should be replacing my tires / brake pads.
Am I correct in assuming that brake pad should be replaced when they are 2/3 worn. The new RAPCO pad I purchased a while ago have a small divot on the end which I assume is a wear indicator. Is this correct?
How long should tires last? Is there a good way to tell when they need replacement?
Cheers
Les
C-GCWZ Flying
C-GROK some assembly required
Bob Turner
PostPosted: Fri Jul 07, 2017 8:35 pm    Post subject: Re: Tire / Brake Life Reply with quote
2/3 wear on the pads is about right. You can go as thin as you like as long as you don't start rubbing the disk with the rivets that hold the pads.
Tires are your call, as long as the cord isn't showing.
Bob Turner
RV-10 QB
kearney
PostPosted: Sat Jul 08, 2017 3:36 pm    Post subject: Re: Tire / Brake Life Reply with quote
Hi Bob
Thanks for the info. It will be most useful, I don't know much about tires.
Cheers
Les
