mhealydds
Posted: Sun Jul 16, 2017 3:43 pm Post subject: RPM Issue |
Newish RV-10 (70 hours). So far I have had no problems since ending build with flight but during run up on today's flight rpm was normal at idle but with power quickly shot up to over 2000 (at lower than normal throttle setting) and rapidly dropped off during single mag use. Prop cycle gave no real change in pitch (no audible change). Tried high speed down taxiway and rpm went into red again. Took off cowl and linkage to govenor was fine and no other obvious problems other than engine maybe hot (or it just seemed that way as 95 outside). I have hartzell govenor from vans. Does that mean bad governor you think?
Matt
Tim Olson
Posted: Sun Jul 16, 2017 4:19 pm Post subject: RPM Issue |
Right now all you said is that the RPM went up to 2000. Without having actual RPM numbers, I'm not sure what to say. You said the RPM went into the red, but are you saying that there is a red on the low-end or the high-end? It's not clear if you mean that it actually went over 2700 RPM.
Quote: | On Jul 16, 2017, at 6:43 PM, mhealydds <mhealydds(at)gmail.com> wrote:
Matt
http://forums.matronics.com/viewtopic.php?p=471079#471079
mhealydds
Posted: Sun Jul 16, 2017 4:31 pm Post subject: Re: RPM Issue |
Sorry typing in heat and sun. Yes redline over 2700 skips from 1100 to over 2700 (maxed 2850 before reduce throttle)with increase in throttle.
Lenny Iszak
Posted: Sun Jul 16, 2017 4:36 pm Post subject: Re: RPM Issue |
Make sure it's not just a displayed rpm problem. How are you getting the RPM signal?
Did your brakes start dragging? It's not easy to hold the plane in place at 2700rpm.
Below around 1400rpm the Hartzell governor will not change pitch.
If it's real RPMs, I'd call Hartzell, their tech support is awesome.
_________________ Lenny Iszak
Palm City, FL
2014 RV-10, N311LZ - 500 hrs |
Posted: Sun Jul 16, 2017 5:46 pm Post subject: RPM Issue |
Add the resistor & you'll be good to go.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
C: 352-427-0285
F: 815-377-3694
Quote: | On Jul 16, 2017, at 8:36 PM, Lenny Iszak <lenard(at)rapiddecision.com> wrote:
Lenny Iszak
Palm City, FL
2014 RV-10, N311LZ - 300 hrs
http://forums.matronics.com/viewtopic.php?p=471085#471085
Kelly McMullen
Posted: Sun Jul 16, 2017 6:21 pm Post subject: RPM Issue |
If the RPMs are real, that you really got 2850...which I kind of doubt or your high speed taxi would have been an airborne event..
You need to get the Lycoming service bulletin for engine overspeeds. IIRC 5% or 2835 is the threshold for inspecting and possibly replacement of some items.
-sent from the I-droid implanted in my forearm
On Sun, Jul 16, 2017 at 5:36 PM, Lenny Iszak <lenard(at)rapiddecision.com (lenard(at)rapiddecision.com)> wrote:
Quote: | --> RV10-List message posted by: "Lenny Iszak" <lenard(at)rapiddecision.com (lenard(at)rapiddecision.com)>
Lenny Iszak
Palm City, FL
FORUMS -
WIKI -
b Site -
-Matt Dralle, List Admin.
A&P/IA, EAA Tech Counselor
KCHD |
Bob Turner
Posted: Sun Jul 16, 2017 8:33 pm Post subject: Re: RPM Issue |
Agree with others - check your tach. At rest or taxi speeds the mechanical prop stop should not allow 2800 RPM.
_________________ Bob Turner
RV-10 QB |
mhealydds
Posted: Mon Jul 17, 2017 5:26 pm Post subject: Re: RPM Issue |
Thanks for all your help. It definitely a sensor problem after some further checking. Working on a fix. Thanks for getting my head straight.
Matt
mhealydds
Posted: Tue Jul 18, 2017 6:40 pm Post subject: Re: RPM Issue |
Update for those of you that it may apply to. Turns out with latest AFS update they added the ability to customize two separate ignition settings in the RPM control menu in those with AFS and SV-EMS. This new ignition section was set to default of two pulses per 2 revolution but for six cylinder should be three pulses. One quick change and all reads OK. One of those ah ha moments I guess
