Relative position of Transponder and DME antennas
bobsv35b(at)aol.com
PostPosted: Tue Jul 18, 2017 2:53 pm    Post subject: Relative position of Transponder and DME antennas Reply with quote
Good Afternoon Peter,
May I ask whether or not you will have an IFR approved GPS in the RV?
If so, why not forget about installing the DME? The GPS can be used as a substitute for ANY DME function. Saves time, money, and weight!
Happy Skies,
Old Bob
Peter(at)sportingaero.com
PostPosted: Wed Jul 19, 2017 12:51 pm    Post subject: Relative position of Transponder and DME antennas Reply with quote
Hello Bob,
Yes I will have an IFR GPS, and no, the DME isn’t optional. In Europe enough approaches have DMEs where the range is ‘slugged’ to read zero at the threshold that trying to use GPS will get you in trouble. Sadly Eurocontrol do not have the same opinion on the substitution of DME with GPS as the FAA. Its bad enough for an amateur pilot to fly the approach accurately without having to figure out the actual range!!
Regards, Peter
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of bobsv35b(at)aol.com
Sent: 18 July 2017 23:53
Subject: Re: Relative position of Transponder and DME antennas
Happy Skies,
Old Bob
