B&C Alternator Conversion and Russian Horizon
Ernie
PostPosted: Thu Jul 27, 2017 2:50 am    Post subject: B&C Alternator Conversion and Russian Horizon Reply with quote
The AI's and T&B are powered by mechanical Inverters (motor generators) which convert 28 vdc to AC 400hz (can't remember the voltage).
On Thu, Jul 27, 2017 at 6:42 AM Yakjumper <tobias(at)macnews.de (tobias(at)macnews.de)> wrote:
--> Yak-List message posted by: "Yakjumper" <tobias(at)macnews.de (tobias(at)macnews.de)>
The original mechanical voltage regulator and horizon draw 3.6A (on startup a bit more)
You can save 1 amp by using an electronic voltage supply for the horizon. The turn/bank also runs on that 3 phase voltage from the regulator.
The electronic one also weighs less.
http://forums.matronics.com/viewtopic.php?p=471309#471309
dsavarese0812(at)bellsout
PostPosted: Thu Jul 27, 2017 2:54 am    Post subject: B&C Alternator Conversion and Russian Horizon Reply with quote
36 volts AC
Dennis
To: yak-list(at)matronics.com
Sent: Thursday, July 27, 2017 6:51 AM
Subject: Re: Re: B&C Alternator Conversion and Russian Horizon
