Backup Alternator / Backup Battery Sanity Check
art(at)zemon.name
PostPosted: Sun Aug 06, 2017 9:42 am    Post subject: Backup Alternator / Backup Battery Sanity Check Reply with quote
Folks,
Can you give me a sanity check? I am building a Bede BD-4C with an MGL EFIS. This is largely a mechanical airplane so manual trim, no gear motors, manual flaps, etc. Between the low current consumption of the EFIS and using LED lights, a backup alternator will run everything in the airplane except the pitot heater; the typical current draw is 21.57 amps and maximum is 31.49 amps. (Pitot heat adds 10 amps.)
With that in mind, I plan on including a 30 amp backup alternator and no backup battery. I figure:
  • If the engine is turning, I will certainly have one of the two alternators operable.
  • If the engine is not turning, the main battery ought to keep the electrons flowing until I reach the ground.
Am I missing anything?
    -- Art Z.
https://CheerfulCurmudgeon.com/"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel
PostPosted: Sun Aug 06, 2017 12:13 pm    Post subject: Re: Backup Alternator / Backup Battery Sanity Check Reply with quote
With the pitot heater shut off, I would expect the continuous current draw to be closer to 10 amps. Have you actually measured 21 amps? Regardless, the backup alternator should run everything.
Joe Gores
art(at)zemon.name
PostPosted: Sun Aug 06, 2017 5:47 pm    Post subject: Backup Alternator / Backup Battery Sanity Check Reply with quote
Joe,
See the Amps table on my electrical system overview diagram. It comes to 21.57 amps typical, 31.49 amps maximum.
    -- Art Z.
On Sun, Aug 6, 2017 at 3:13 PM, user9253 <fransew(at)gmail.com (fransew(at)gmail.com)> wrote:
Joe Gores
PostPosted: Sun Aug 06, 2017 6:42 pm    Post subject: Re: Backup Alternator / Backup Battery Sanity Check Reply with quote
Art, I see what you mean. It will be interesting to see how measured current compares to calculated current. You have nice neat documentation.
Joe Gores
