Analog electric clock with a relay circuit for battery cap
PostPosted: Wed Aug 09, 2017 9:27 am    Post subject: Analog electric clock with a relay circuit for battery cap Reply with quote
At 06:28 PM 8/8/2017, you wrote:
Bob,
Some time ago you posted a simple circuit for doing an approximation of battery capacity. The circuit consisted of an analog electric clock to measure the time required to discharge a battery, through a light bulb, down to 10 volts. I would like to build one of these to use as an annual battery condition test. Can you direct me to where I might find information on how to make one?
Yeah . . . that was a pretty crude, first
pass at a po' boy's cap checker. That
article can be found here:
http://tinyurl.com/ybvx57bu
There's a more accurate and convenient version of
that project in the works but the device
in the article will produce good benchmark
numbers for your battery's 'stage of service
life'.
