Analog electric clock with a relay circuit for battery capa
cluros(at)gmail.com
PostPosted: Fri Aug 11, 2017 3:22 pm    Post subject: Analog electric clock with a relay circuit for battery capa Reply with quote
This looks pretty fancy for the price. I have a 20% coupon so it comes to $55.
https://www.harborfreight.com/digital-automotive-battery-analyzer-66892.html
  • Checks voltage, cold cranking amps (CCA), resistance and overall battery condition
  • Continuous testing will not damage battery
  • Uses car battery for power, no extra internal batteries needed
Does the list think this will do the job?
On Wed, Aug 9, 2017 at 10:26 AM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
At 06:28 PM 8/8/2017, you wrote:
Some time ago you posted a simple circuit for doing an approximation of battery capacity.  The circuit consisted of an analog electric clock to measure the time required to discharge a battery, through a light bulb, down to 10 volts.  I would like to build one of these to use as an annual battery condition test.  Can you direct me to where I might find information on how to make one?
  Yeah . . . that was a pretty crude, first
  pass at a po' boy's cap checker. That
  article can be found here:
http://tinyurl.com/ybvx57bu
  There's a more accurate and convenient version of
  that project in the works but the device
  in the article will produce good benchmark
  numbers for your battery's 'stage of service
  life'.
