Parts needed: Old style Ivo prop adjustment cams
Jerry-TS-MkII
PostPosted: Tue Aug 29, 2017 10:06 am    Post subject: Parts needed: Old style Ivo prop adjustment cams Reply with quote
Hello everyone,
Having a OLD STYLE 3 blade Ivo that I hope to use initially on my Twinstar Mk II, it came without the adjustment cams or adjustment shims. This prop doesn't have the large "easy to adjust external screw and lock nut") So it's at 6 degrees as I read the "no-cam" default. Ideally, I need to find/make/buy 3 cams, and a set of shims.. but I can make either if needed. The shims just round plates, of unknown thickness (at this point) that stack in front, or behind the prop blades, to move the 3 cams.
Not sure if Ivo will send me any drawings since they are discontinued parts. But apparently they just have a screw (and some Lock-tite) holding them onto the end of the torque rod in the prop blade. If anyone has converted from 3 blade to 2, and has a spare blade w/cam, and would be willing to sell 3, or 1, or send me one cam and shim to duplicate, I'd gladly return with a coupon to your pub of choice, or health-food store, (I find them to be one and the SAME place myself.. but others might not). Someone's junk drawer probably has one (or more). But if like my shop, 3 weeks to find them would be the problem.. LOL. Any productive thoughts, sources, manifest instructions, etc, all welcome! Thanks, Jerry
