914 turbo rpm.
philipgeorge347(at)hotmai
PostPosted: Fri Sep 08, 2017 4:30 am    Post subject: 914 turbo rpm. Reply with quote
What sort of rpm. Should be expected at take off with a 914 Turbo at the beginning of the take off run and in the climb. Thanks in advance.
Phil George.
Sent from my Samsung device
ken carp
PostPosted: Fri Sep 08, 2017 6:01 am    Post subject: 914 turbo rpm. Reply with quote
I get 5800 with Air master controlled prop. I cut back to 5500 once couple hundred feet in the air. The max rpm set in the prop hub.
Sent from my iPadKen Carpenter
On Sep 8, 2017, at 8:28 AM, philip george <philipgeorge347(at)hotmail.com (philipgeorge347(at)hotmail.com)> wrote:
Phil George.
ken carpenter
rlborger(at)mac.com
PostPosted: Fri Sep 08, 2017 8:05 am    Post subject: 914 turbo rpm. Reply with quote
Phil,
Do you have a fixed pitch or contact speed prop?
My 914 with Airmaster constant speed prop will reach 5800 rpm (max allowed) on takeoff.
Blue skies & tailwinds,Bob BorgerEuropa XS Tri, Rotax 914, Airmaster C/S Prop (125 hrs).Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP3705 Lynchburg Dr.Corinth, TX 76208-5331Cel: 817-992-1117rlborger(at)mac.com (rlborger(at)mac.com)On Sep 8, 2017, at 7:28 AM, philip george <philipgeorge347(at)hotmail.com (philipgeorge347(at)hotmail.com)> wrote:
Phil George.
PostPosted: Fri Sep 08, 2017 8:46 am    Post subject: 914 turbo rpm. Reply with quote
Hi Robert
It's my friends tri gear Europa undergoing flight testing . It's a Airmaster constant speed also.
Phil George.
Date: 08/09/2017 17:10 (GMT+00:00)
Subject: Re: 914 turbo rpm.
Phil,
Blue skies & tailwinds, Bob Borger Europa XS Tri, Rotax 914, Airmaster C/S Prop (125 hrs). Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP 3705 Lynchburg Dr. Corinth, TX 76208-5331 Cel: 817-992-1117 rlborger(at)mac.com (rlborger(at)mac.com) On Sep 8, 2017, at 7:28 AM, philip george <philipgeorge347(at)hotmail.com (philipgeorge347(at)hotmail.com)> wrote:
Phil George.
ken carp
PostPosted: Fri Sep 08, 2017 2:42 pm    Post subject: 914 turbo rpm. Reply with quote
If turbo not kicking in, the manifold pressure only goes up to about 27 inches and rpm to about 5000. Usual boosted pressure 40 inches
On Sep 8, 2017, at 12:03 PM, Robert Borger <rlborger(at)mac.com (rlborger(at)mac.com)> wrote:
Phil,
Phil George.
ken carpenter
