intermittent landing gear issue
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> L29-List
skidmk
PostPosted: Sat Sep 09, 2017 5:31 am    Post subject: intermittent landing gear issue Reply with quote
folks, recent intermittent issue with landing gear. Need some advice or thoughts about it.
condition:
hydraulic system full
accumulators 75-80
all systems functioning (flaps, speed brakes)
all other systems normal
Take off, cycle gear it starts then stays stuck varying levels of "upness, sometimes a little, sometimes almost up, brake is cycling (to brake the spinning wheels) very little movement of pole retraction
push the down button, they lock up and we get poles and greens.
cycle up, same as before.
cycle down, lock and land.
open the drain in the right wing a bit, no air comes out, let the fluid drip a little (4-8 drops) tighten it up, test flight everything works.
of note, when opening the hydraulic tank to check levels the fluid is quite frothy (cavitation)
anyone see this, or have an idea as to where to start to trouble shoot. it is intermittent. flew 10 flights last weekend with no problems
thanks
- The Matronics L29-List Email Forum -
http://www.matronics.com/Navigator?L29-List
Mike "Skidmk" Bourget
Ottawa, Ontario
Dawg
PostPosted: Sat Sep 09, 2017 5:38 am    Post subject: intermittent landing gear issue Reply with quote
in the right wheel well, how many drain valves do u have? One is over the main wheel the other will be on leading edge. If only one, it is the flap drain. the gear drain is in the cockpit. Emergency valves closed completely?
Sent from my Samsung Galaxy smartphone.
-------- Original message --------
Date:2017/09/09 7:31 AM (GMT-07:00)
To: l29-list(at)matronics.com
Cc:
Subject: L29-List: intermittent landing gear issue
Dawg
Dawg
PostPosted: Sat Sep 09, 2017 5:40 am    Post subject: intermittent landing gear issue Reply with quote
also the fluid level needs to be about an inch from the top. disregard the dip stick.
Cc:
Dawg
skidmk
PostPosted: Sat Sep 09, 2017 6:18 am    Post subject: Re: intermittent landing gear issue Reply with quote
thanks Dawg,
confirmed the emergency valves in both pits closed. There is only 1 drain in the right wing. it is right above the tire/wheel assembly. I cannot see any other drains near the leading edge or other.
where in the front pit is it accessed? the fluid is as you've described.
thanks for your quick reply.
M
Ottawa, Ontario
Dawg
PostPosted: Sat Sep 09, 2017 8:22 am    Post subject: intermittent landing gear issue Reply with quote
on the left side wall below the throttle. red knob. 2 full turns open. leave open for a few minutes. go fly. u can do it in the air if needed.
Date:2017/09/09 8:18 AM (GMT-07:00)
Cc:
Subject: L29-List: Re: intermittent landing gear issue
Dawg
colyergreg(at)aol.com
PostPosted: Sat Sep 09, 2017 9:49 am    Post subject: intermittent landing gear issue Reply with quote
I had issue like that too. Turned out to be my hydraulic pump. Started with intermittent speed brakes until they stopped working. Then the gear only worked at high throttle settings.. replaced the pump all was good
Gregory "Wired" Colyer
www.AceMakerAirshows.com
415-531-0970
Join us on Facebook
www.facebook.com/AceMakerAirshows
Twitter (at)AceMaker33
On Sep 9, 2017, at 8:18 AM, skidmk <skidmk(at)gmail.com> wrote:
thanks Dawg,
M
Mike &quot;Skidmk&quot; Bourget
Ottawa, Ontario
http://forums.matronics.com/viewtopic.php?p=472706#472706
skidmk
PostPosted: Sat Sep 09, 2017 11:30 am    Post subject: Re: intermittent landing gear issue Reply with quote
dawg,,, yes the hydraulic dump valve. I don't think this was properly serviced after the annual and the gear were cycled. as well as the e-gear testing.
So I unscrewed it (the hydraulic dump valve), let it sit. Drained the flap valve as well. Went flying everything worked well.
So, I'll monitor. It could very well be a faulty pump or "intermittent failing pump" thanks guys.
Ottawa, Ontario
Dawg
PostPosted: Sat Sep 09, 2017 3:15 pm    Post subject: intermittent landing gear issue Reply with quote
good. I have hyd. pump overhaul kits.
Date:2017/09/09 1:31 PM (GMT-07:00)
Cc:
Dawg
skidmk
PostPosted: Fri Sep 22, 2017 8:06 am    Post subject: Re: intermittent landing gear issue Reply with quote
Thanks for all the advice, 2 flights now zero issues, after having "serviced the aircraft" bleed valves.
Ottawa, Ontario
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> L29-List All times are GMT - 8 Hours
