Rotax 912r in oil
tc1917(at)bellsouth.net
PostPosted: Fri Sep 15, 2017 1:17 am    Post subject: Rotax 912r in oil Reply with quote
Anyone ever have a little white slime in there radiator overflow tank? Doesnt seem like oil. No water in oil. No oil missing. No water missing. Just this smudge of white foam left when water gets sucked back into radiator. All temps normal. Ted cowan. Slingshot 912 ul zoom zoom
rmurrill(at)cox.net
PostPosted: Fri Sep 15, 2017 5:03 am    Post subject: Rotax 912r in oil Reply with quote
Yes .. Often visible inside radiator cap and tank lip...small amount. Had
it with the yellow/green mix. Same with recently installed orange mix
antifreeze. Also noted that after removing heater, and changing 5 ft of 1
inch rubber hose to aluminum tube water pressure goes way down during low
throttle/descent. No water loss.
Bob
