Search for gear front selector as spare part
marty.jpm(at)gmail.com
PostPosted: Fri Sep 22, 2017 12:44 am    Post subject: Search for gear front selector as spare part Reply with quote
Dear All,
I own and fly a YAK 52 (year 1987) and I've been facing recurrent issues with the gear selector at the front. It was several times machined an d repaired but without durable results: it always leaks, more and more. I must exchange it.
Do you have such a part as spare in your stocks? A new one would be perfect if still available. BTW, same request for the selector at the rear, that I'd like to change too.
Thank you in advance for your assistance!
Jean-Philippe "Marty"
France
Yakjumper
PostPosted: Fri Sep 22, 2017 1:08 am    Post subject: Re: Search for gear front selector as spare part Reply with quote
Hi,
just replaced a leaky rear flap selector and sent it for overhaul to Aviaserv.
He has new/overhauled ones.
Or mail me (I am in Germany), I have a new rear gear selector as a spare.
btw:
The flap selector leaked so much that during flight the main air tank was drained, the compressor could not keep up. Had to close the air valve in flight to preserve some pressure for landing and braking. Luckily I already had a spare part in stock, so no waiting.
dsavarese0812(at)bellsout
PostPosted: Fri Sep 22, 2017 2:51 am    Post subject: Search for gear front selector as spare part Reply with quote
Doug Sapp, our CJ6 parts guru, usually has new front gear/flap selector valves as well as new rear gear selectors in stock.
Dennis
From: Jean-Philippe Martel <marty.jpm(at)gmail.com>
To: yak-list(at)matronics.com
Sent: Friday, September 22, 2017 4:45 AM
Subject: Search for gear front selector as spare part
Dear All,
France
dougsappllc(at)gmail.com
PostPosted: Fri Sep 22, 2017 6:29 am    Post subject: Search for gear front selector as spare part Reply with quote
Jean-Philippe / Dennis,
Yes we have both in stock, but simply replacing it will not solve the root problem.  Your pneumatic system is making moisture and if not corrected you will be replacing them again in a year or so.  You might consider checking your pneumatic desiccant filter, if you have one.  If you do not have one installed, we do carry the stainless steel version in our stock.
Best,
Doug
On Fri, Sep 22, 2017 at 3:50 AM, A. Dennis Savarese <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)> wrote:
Dennis
From: Jean-Philippe Martel <marty.jpm(at)gmail.com (marty.jpm(at)gmail.com)>
Dear All,
France
PostPosted: Sat Sep 23, 2017 1:58 am    Post subject: Search for gear front selector as spare part Reply with quote
Hi Doug,
Thanks a lot for the wise technical advise.  I have no pneumatic dessicant filter.  Here, on the other side of the Atlantic, in the "old world", we have different rules. Before I consider the installation of such dessicant filter, my YAK 52 being registered in UK, I have first to ask to my Welsh workshop whether it is approved by the CAA UK.
I do it and get back to you asap.
All the best,
JP "Marty"
Le 22 sept. 2017 16:34, "doug sapp" <dougsappllc(at)gmail.com (dougsappllc(at)gmail.com)> a écrit :
Best,
Doug
Dennis
Dear All,
France
PostPosted: Mon Sep 25, 2017 12:31 am    Post subject: Search for gear front selector as spare part Reply with quote
Hi Tobias,
thanks for your kind feedback.
Indeed my priority number 1 is the front valve.
I'm trying to find a new one. I'm going to ask to AVIASERV, that's a good idea.
Best regards,
France
2017-09-22 11:08 GMT+02:00 Yakjumper <tobias(at)macnews.de (tobias(at)macnews.de)>:
--> Yak-List message posted by: "Yakjumper" <tobias(at)macnews.de (tobias(at)macnews.de)>
Hi,
btw:
http://forums.matronics.com/viewtopic.php?p=473055#473055
List" target="_blank" rel="noreferrer">http://www.matronics.com/Navigator?Yak-List
FORUMS -
_blank" rel="noreferrer">http://forums.matronics.com
WIKI -
lank" rel="noreferrer">http://wiki.matronics.com
b Site -
          -Matt Dralle, List Admin.
target="_blank" rel="noreferrer">http://www.matronics.com/contribution
fishface68
PostPosted: Thu Sep 28, 2017 11:21 am    Post subject: Re: Search for gear front selector as spare part Reply with quote
marty.jpm(at)gmail.com wrote:
Hi Doug,
All the best,
JP "Marty"
We are operating a Yak52 in the UK so would be very interested if anyone has been able to get the desiccant filter approved as a mod.It would be good to be able to open the snot valve from the cockpit to unload the compressor also. Lubricant for the pneumatics should be a silicon oil also not glycerine and alchohol which i understand was used in the soviet union when the original spec was unavailable.
Best Wishes Pat
