Canopy Protective Coating
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Lightning-List
stephenbehn(at)bigpond.co
PostPosted: Wed Sep 27, 2017 2:43 am    Post subject: Canopy Protective Coating Reply with quote
Hello Group,
Has anyone had success with removing the protective coating on the canopy bubble other than with your thumb nail. Its easy where the coating is thick but on the inside it is really thin and almost impossible to get off.
Cheers
Steve Behn
Lightning 69
- The Matronics Lightning-List Email Forum -
http://www.matronics.com/Navigator?Lightning-List
n5pb(at)AOL.COM
PostPosted: Wed Sep 27, 2017 8:36 am    Post subject: Canopy Protective Coating Reply with quote
Steve, I scrapped mine at the factory. they had a scraper which I believe was made out of Plexiglas and worked perfectly. Check with Nick.
He might be able to give you more info, since this was several years ago.
Bear
PostPosted: Sun Oct 01, 2017 8:51 pm    Post subject: Canopy Protective Coating Reply with quote
Bear thanks for the suggestion I made up a plexi glass scraper out of a cut off piece of the canopy, did get a few light scratches using it but was able to polish them out with metal polish. It was a really slow and tedious job. I am sure it was so because the film had been on the canopy for a long time and had hardened on there. If anyone has an older kit with the canopy still protected I would remove it and reapply a new thick coat Aircraft Spruce seem to have it.
Steve
Sent: Thursday, September 28, 2017 2:34 AM
To: lightning-list(at)matronics.com (lightning-list(at)matronics.com) ; nick(at)flylightning.net (nick(at)flylightning.net)
Subject: Re: Canopy Protective Coating
Bear
-----Original Message-----
To: lightning-list <lightning-list(at)matronics.com>
Sent: Wed, Sep 27, 2017 7:35 am
Subject: Canopy Protective Coating
Hello Group,
Cheers
Steve Behn
Lightning 69
n5pb(at)AOL.COM
PostPosted: Mon Oct 02, 2017 5:31 am    Post subject: Canopy Protective Coating Reply with quote
Steve,
glad you were able to get the film off. As I recall, it did take me a little while too to scrape the film off the entire canopy. I do think the canopy was relatively new and the film hadn't "hardened", but it was tedious.
Continued luck with your build...
Bear
N82PB
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Lightning-List All times are GMT - 8 Hours
You cannot download files in this forum
