Posted: Fri Oct 13, 2017 9:17 pm Post subject: Panel Depth |
I was pondering my panel today and its depth. My plan is to run a full glass
panel, with a couple of "smart Single" units as
Backups for ASI Alt etc. Given most of these units are now only about 5
inches deep, there is a significant void left behind them
So I thought shortening the panel depth (fore - Aft ) would visually at
least make the interior feel bigger. Has anyone done this
Or considered it and aborted it part way through, if so why, and if you have
done it was it worth the time.
Regards and thanks
Craig
Kit577
spcialeffects
Posted: Sat Oct 14, 2017 11:51 pm Post subject: Re: Panel Depth |
Hey Craig. Once you get all your wiring in, both in the panel and on the firewall, you will be struggling for space........that's what I found. Good luck
Frank Xuereb, kit #165
Posted: Sun Oct 15, 2017 2:17 pm Post subject: Panel Depth |
Ok thanks frank
christoph.both(at)acadiau Guest
Posted: Mon Oct 16, 2017 8:08 am Post subject: Panel Depth |
Same here, once all is installed, especially wires, the panel really fills up fast behind. Perhaps consider thinning out the cushion behind your back by 2 inches. Not much is needed for comfort and you gain 2 inches space and can possibly stretch out one of your feet between both rudder pedals while in cruise…
Christoph Both
#223 Wolfville NS Canada
On 2017-10-15, 19:17, "owner-europa-list-server(at)matronics.com on behalf of craig" <owner-europa-list-server(at)matronics.com on behalf of craigb(at)onthenet.com.au> wrote:
Ok thanks frank
Posted: Tue Oct 17, 2017 1:41 am Post subject: Panel Depth |
Ok thanks Christoph
--> <christoph.both(at)acadiau.ca>
Same here, once all is installed, especially wires, the panel really fills up fast behind. Perhaps consider thinning out the cushion behind your back by 2 inches. Not much is needed for comfort and you gain 2 inches space and can possibly stretch out one of your feet between both rudder pedals while in cruise Christoph Both
Ok thanks frank
